Plot fourier series in matlab
  1. Sep 21, 2014 #1
    etf
    Hi!
    Here is my m-file for Fourier series plot:
    clear
    clc
    syms n
    a0=input('Enter coefficient a0: ');
    an=input('Enter coefficient an: ');
    bn=input('Enter coefficient bn: ');
    a=input('Enter lower boundary: ');
    b=input('Enter upper boundary: ');
    t=linspace(a,b,10000);
    sum=0;
    for n=1:10 %%n could be any number, bigger n - better approximation
    sum=sum+(subs(an,'n',n).*cos(2.*n.*pi.*t./(b-a))+subs(bn,'n',n).*sin(2.*n.*pi.*t./(b-a)));
    end
    series=a0+sum;
    plot(t,series)
    grid
    Problem is, it is so slow! How should I modify it in order to increase speed?
  3. Sep 22, 2014 #2
    analogdesign
    Don't use a for loop. Do a matrix operation. That's what Matlab is designed for and it is much, much faster when you use it in that way.
  4. Sep 23, 2014 #3
    etf
    What do you mean exactly by matrix operation? Here is how I solved it
    clear
    clc
    a0=input('Enter a0: ');
    an=input('Enter an: ','s');
    bn=input('Enter bn: ','s');
    a=input('Unesi upper limit: ');
    b=input('Unesi lower limit: ');
    k=input('Enter number of terms: ');
    %original=input('Unesi originalnu funkciju f(t): ');
    suma=0;
    for n=1 : k
    ebn = evalin('caller',bn);
    ean = evalin('caller',an);
    suma = suma + (ean.*cos(2.*n.*pi.*t./(b-a)) + ebn.*sin(2.*n.*pi.*t./(b-a)));
    end
    red=a0+suma;
    plot(t,red)
    grid
  5. Sep 23, 2014 #4
    etf
    It should be:
    a=input('Unesi lower limit');
    b=input('Unesi upper limit: ');
  6. Sep 23, 2014 #5
    olivermsun
    The slowness isn't due to the 10 loop iterations. It's due to the use of symbolic math in the statements:
    Code (Text):
    syms n
    subs(…)
    Also, does the OP really want to ask for an, bn only once each, or should they be inside a loop as well?
  7. Sep 23, 2014 #6
    analogdesign
    I agree but I assumed the n=10 was for debugging. The OP will get a pretty poor Fourier series with n=10. At any rate, it's a good idea to use Matlab correctly because treating it like a regular programming language will end up biting you in the butt.
  8. Sep 23, 2014 #7
    olivermsun
    I agree with your sentiment, but in this case I first want to be sure the OP understands what he/she is trying to do, independent of Matlab. :)
  9. Sep 23, 2014 #8
    etf
    I used small number of n (n=10) to show that for even small number of terms it takes a lot of time for plot. For good approximion one should use thousands of terms and it wouldn't be completed in next 100 years using my code involving symbolic math :)
  10. Sep 23, 2014 #9
    analogdesign
    Totally agree with what you and Oliver said. However, it's not a bad idea to think in terms of matrix operations because if you end up using Matlab for anything serious it will take forever to work if you have a lot of for loops. I've seen speed differences over over 100 times by doing large matrix operations instead of large for loops.
    That said, if you're just using it for a class and not for work or research, it might not be a big deal. Just keep in mind that to really unlock the power of Matlab you need to think in terms of matrices.
  11. Sep 23, 2014 #10
    etf
    I would like to try your method but I'm not sure I understand it :(
  12. Sep 23, 2014 #11
    analogdesign
  13. Sep 23, 2014 #12
    olivermsun
    Ah very good! I was looking for that help page to link for etf, but I couldn't remember what it was named.
  14. Sep 23, 2014 #13
    etf
    Thanks a lot guys!
