I Plotting corrected values
  1. Oct 4, 2016 #1
    I have the equation
    ##qV = E_g + T[kln(\frac{I}{A}) - (3 + \frac{\gamma}{2})kln(T)]##
    So if I plot ##qV## against ##T## that'll be a straight line with the y-intercept being ##E_g##. But then my lab manual says a more precise value of ##E_g## can be found by plotting the corrected value
    ##qV_c = qV + (3 + \frac{\gamma}{2})kTln(T)##
    So does that mean if I want to plot ##qV_c## against ##T##, which I think is what's being asked, then I should plot
    ##qV_c = E_g + kTln(\frac{I}{A})##
    And I'll get my more accurate ##E_g##?
  3. Oct 4, 2016 #2
    BvU
    2017 Award
    Hi,
    You can't plot ##E_g## to find ##E_g##. (which probably is also not how I should understand your last line (*))
    Your first
    ignores the ##
    - (3 + \frac{\gamma}{2})kln(T)## in the full ##qV## expression. I suppose this is a small disturbance (?) and ##qV_c## is an attempt to get a more linear relationship.
    You really want to plot ##qV_c## against ##T## ((*) which I think is how I should understand your last sentence).
    But of course, the proof of the pudding is in the eating. Does it indeed yield a more linear graph ?
    PS if you want to avoid things like ##kln## in ##\TeX## use \ln to get ##k\ln##
  4. Oct 4, 2016 #3
    Sorry, should have made it clearer. :) As you thought, I meant I'll plot the corrected value of ##qV_c## against ##T## and the intercept of that graph will be my more accurate ##E_g##. I think I can consider the ##- (3 + \frac{\gamma}{2})kln(T)## to be constant for ##T## in the range 200 to 400 Kelvin, where all measurements will be taken, but probably the correction tries to deal with inaccuracies caused by that assumption. And thanks for the tip, I'll switch to ##\ln## in future!
  5. Oct 4, 2016 #4
    Plotting your first equation vs. T will not give a straight line as there is a ln(T) term. Plotting
    vs. T will give a straight line since T is now appearing linearly on the right hand side of the equation. The intercept of that straight line on the vertical axis will be Eg.
  6. Oct 8, 2016 #5
    If I sub ##qV = qV_c - (3 + \frac{\gamma}{2})kT\ln(T)## into my first equation, that gives
    ##qV_c = E_g + kT\ln(\frac{I}{A})##
    Which is linear in ##T##. Are you saying that's what I should plot, or just plot
    ##qV_c = qV + (3 + \frac{\gamma}{2})kTln(T)##?
  7. Oct 8, 2016 #6
    BvU
    2017 Award
    How about doing it instead of asking ?
  8. Oct 8, 2016 #7
    ZapperZ
    Staff Emeritus
    Education Advisor
    Please note that only this equation
    [tex]qV_c = E_g + kT\ln(\frac{I}{A})[/tex]
    will give you a linear equation in T if you plot qVc versus T. All the others that you wrote have extra "T" hanging around elsewhere in the equation.
    Zz.
  9. Oct 8, 2016 #8
    I don't actually have any data yet. And I know only one of the equations is linear, therefore must be the right one, so checking which one to plot was unecessary except for my peace of mind, I suppose. Bad habit of mine. Thanks for your help everyone! :)
Have something to add?
Draft saved Draft deleted
