Plotting Data in Mathematica
  1. Jun 23, 2009 #1
    I am importing data as a .dat file into Mathematica and making a list plot. I need to know: a)How to sort the words out of my data? I used to use AllNumeric but that went away with version 6
    b)How to switch the axis on my graph? My data is coming in as a pair sequence {1#`,2#`} but I need it to be {2#`,1#`} Or I need to know how to rotate my plotting sequence so it will flip.
    This is the code I am using
    data=Import["Test2.dat","Data"];
    b=Drop[data,5]; %This just removes the header from my data file
    ListPlot
  3. Jun 23, 2009 #2
    diazona
    Try this:
    Code (Text):
    b=Reverse[Drop[data,5],2];
    ListPlot[b]
  4. Jun 23, 2009 #3
    Thanks!
  5. Jun 23, 2009 #4
    Does you know how to sort words out of data? I have lists of data combined into one sheet and need to remove the column headings out of the data before it is plotted.
  6. Jun 23, 2009 #5
    diazona
    Can you post an example in more detail?
  7. Jun 23, 2009 #6
    It has two columns of that are combined lists of test data. Every so often there will be titles and headings inserted into the two columns and I need to delete these in order to use the ListPlot command.
    Unfortunately I cannot upload it in a large section so there is just the start of it attached.
    Thank you for all of your help
Similar Discussions: Plotting Data in Mathematica
  1. Mathematica plot (Replies: 0)
Loading...
