Troubleshooting HT & LT PMT Voltages | Explained by Experts
  • Thread starter neduet
In summary, if one phase link of HT blows out from the HV side of PMT, and there is a loss of protection fuse link to the transformer HV primary, the secondary side will be affected. The secondary LV will have a star with earthed neutral, and the primary HV will be isolated delta connected. This will result in the loss of one phase, causing the secondary LV to have relative phases of 0° or 180°. While the three secondary outputs should still provide power, two will have reduced voltage amplitudes. This is because the loss of one phase removes phase information from the transformer, resulting in the reduced voltage amplitudes.
neduet
64
Hi Friends
What happened when one phase link of HT blowout from hv side of pmt. What happen with LT side.Thanks a lot
Did it lower voltage on secondary side on any single phase?
Whatever are you talking about ? I thought HT Blowout was a punk band.
I think we need less acronyms and more information.
You have lost one protection fuse link to the transformer HV primary.
Why might you have lost one phase? Lightning strike or transformer failure?
What happens to the secondary will depend on;
You have HV, 3 phase to the primary of a transformer.
Does it have a star with neutral at centre or is it isolated delta connected?
You have LV, 3 phase from the transformer secondary.
Is it a star with earthed neutral?
It only takes three wires to maintain 3 phases, one can be neutral.
Likes 1 person
Sorry for less information post,
well,fuse link or drop out link, lost by some reason ,
and secondary LV star with earthed neutral and primary HV isolated delta connected.
what will happen on secondary LV if PMT lost one phase of HV/PRIMARY. and other 2 are healthy in delta connected hv,
thanks
The loss of one of the three connections to the primary removes phase information from the transformer. The secondaries will then have relative phases of 0° or 180°.
The three secondary outputs should continue to provide power, but two will have reduced voltage amplitudes.
sir. Why amplitudes reduced. Little explanation please...
1. What is the purpose of troubleshooting HT & LT PMT voltages?
The purpose of troubleshooting HT & LT PMT voltages is to identify and fix any issues or malfunctions with the high and low tension photomultiplier tube (PMT) voltages. These voltages are essential for proper functioning of the PMT, which is an electronic device used for detecting and amplifying light signals in scientific experiments.
2. How do you troubleshoot HT & LT PMT voltages?
To troubleshoot HT & LT PMT voltages, you will need to use a multimeter to measure the voltages at different points in the circuit. Start by checking the power supply and connections to ensure they are functioning properly. Then, check the voltage output from the PMT and compare it to the recommended values. If the voltage is too high or too low, you may need to adjust the power supply or replace faulty components.
3. What are some common issues that can affect HT & LT PMT voltages?
Some common issues that can affect HT & LT PMT voltages include faulty power supplies, loose connections, damaged components, and incorrect settings. Other factors such as temperature and humidity can also have an impact on the voltages. It is important to regularly check and maintain the PMT system to prevent any potential issues.
4. How can you prevent problems with HT & LT PMT voltages?
To prevent problems with HT & LT PMT voltages, it is important to follow proper maintenance and calibration procedures for the PMT system. This includes regularly checking the power supply, connections, and voltage output, as well as keeping the system clean and free of dust or debris. It is also recommended to have a backup power supply and spare components on hand in case of any malfunctions.
5. When should you seek expert help for troubleshooting HT & LT PMT voltages?
If you are unable to identify or fix the issue with HT & LT PMT voltages on your own, it is recommended to seek expert help. This could include consulting with a fellow scientist or reaching out to the manufacturer for technical support. It is important to address any issues with PMT voltages promptly to avoid potential damage to the system and ensure accurate results in scientific experiments.
  • Electrical Engineering
