Which point is farther from the origin?
In summary, the conversation discusses how to determine which point is farther from the origin on the xy-plane. The distance formula can be used to calculate the distance of both points from the origin, and then compare these distances or the square of the distances. The second given point, (4, 1/2), is found to be farther from the origin than the first point, (3, -2), by comparing their squared distances.
mathdad
1,283
(3, -2) or (4, 1/2)?
I know the origin is the point (0, 0). This is the location on the xy-plane where the x-axis and y-axis meet. Can the distance formula normally used to calculate how far points on the xy-plane are from each other be applied here? If so, how is the distance formula used in this example?
Mathematics news on Phys.org
What you want to do is calculate the distance of both points from the origin, and then compare these distances...or in fact, you could compare the square of the distances. So, we could write:
\(\displaystyle d_1^2=(3-0)^2+(-2-0)^2=13\)
\(\displaystyle d_2^2=(4-0)^2+\left(\frac{1}{2}-0\right)^2=\frac{65}{4}\)
Since \(\displaystyle \frac{65}{4}>\frac{52}{4}=13\), we find the second given point is farther from the origin. :D
Your way is much faster.
1. What is the concept of "Point From the Origin"?
The concept of "Point From the Origin" refers to the position of a point on a coordinate plane in relation to the origin (0,0). The origin is the point where the x-axis and y-axis intersect and serves as the reference point for all other points on the coordinate plane.
2. How is the distance of a point from the origin calculated?
The distance of a point from the origin can be calculated using the Pythagorean theorem. This theorem states that the square of the hypotenuse (the longest side) of a right triangle is equal to the sum of the squares of the other two sides. In the case of a point on a coordinate plane, the hypotenuse is the distance from the point to the origin, and the other two sides are the x-coordinate and y-coordinate of the point.
3. What does a positive or negative value for a point's coordinates indicate?
A positive value for a point's x-coordinate indicates that the point is to the right of the origin, while a negative value indicates that the point is to the left. Similarly, a positive value for a point's y-coordinate indicates that the point is above the origin, while a negative value indicates that the point is below.
4. How does the concept of "Point From the Origin" relate to vector quantities?
Vector quantities have both magnitude (size) and direction. When describing a vector quantity, the starting point or initial point is often referred to as "from the origin". This means that the vector is being measured from the origin point to another point on the coordinate plane.
5. Why is the origin considered a special point on the coordinate plane?
The origin is considered a special point on the coordinate plane because it serves as the reference point for all other points. It is also the point where the x-axis and y-axis intersect, which allows us to easily define and measure distances and angles on the coordinate plane.
  • General Math
  • General Math
  • General Math
  • General Math
