Point of inflection question
  • Thread starter haris123
If g(x) = xe^kx where k < 0 is a constant, then we may conclude that g has
(a) a relative maximum at x = -1/k (b) a relative minimum at x = -1/k
(c) a relative maximum at x = 1/k (d) a relative minimum at x = 1/k
(e) none of (a) - (d)
Answers and Replies
i think the answer should be A
Dick
26,263
619
That would be right. But why do you think so?
the reason is because the graph is decreasing from - infinity to -1/k and increasing from -1/k to infinity. it changes from negative to positive. hence its a maximum. am i right?
Dick
26,263
619
If that's what you think it does, you are wrong. Changing from decreasing to increasing sounds more like a minimum. Can't you give a reason in terms of derivatives?
i am the one who needs help. so you tell me what do you think in terms of derivatives? btw from negative to positive is maximum
You can find out if a point is max. or min. by two methods -
1) Check the sign of f'(x) to the left and right of the point. If it's sign is negative to the left and positive to the right, then the point is a local minima.
2) Find out the value of the second derivative at the given point and check its sign. If it is negative then the point is a local maxima. If it is positive then the point is a local minima.
If f'(x) changes sign from negative to positive as we go through a point from left to right, then that point is a minimum not maximum! Review your calculus notes
Related Threads on Point of inflection question
  • Last Post
  • Last Post
17K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
