How Do You Convert Polar Equations to Cartesian Form and Sketch Them?
In summary, the equation r = 1 + cos(theta) in Cartesian form is expressed in terms of x and y on a polar plot, and can be converted to x and y on a rectangular plot by multiplying by r. When theta is a multiple of pi/2, the points you get on the x and y axes correspond to theta=0, pi/2, pi, 3pi/2.
uniidiot
24
i) Express the equation r = 1 + cos(theta) in Cartesian form.
ii) Sketch the curve whose equation in polar form is r = cos(theta)
x = r cos (theta)
y = r sin (theta)
i) x = r cos (theta) = (1 + cos(theta)) cos (theta)
y = r cos (theta) = (1 + cos(theta)) cos (theta)
i'm not sure that's right?
ii) i have no idea how to sketch it, because there are no figures to work with!
thanks
I'm not sure that we are getting the whole problem statement here, but hopefully I can at least help you with sketching it.
Let's sketch the polar form of the equation. Draw the traditional x,y axis cross, with the y-axis vertical (+ up) and the x-axis horizontal (+ to the right). Now remember that in polar coordinates, r is the distance away from the origin, and theta is the angle formed to that radius r from the + x axis, measured in the counterclockwise direction from the x-axis over to the radius r line.
Now, the equation has a constant offset r = 1, which then gets the cos(theta) term added to it, depending on the angle theta as it sweeps around from zero to 2PI.
So what is the value of r for these main points in the sketch?
theta = 0
theta = PI/2 (90 degrees, which is on the y-axis, right?)
theta = PI (180 degrees, along the - x axis)
theta = 3PI/2 (270 degrees, along the - y axis)
Now that you have those 4 points on the curve, you can start to see what it will look like. Now fill in these next 4 points to get a better idea:
theta = PI/4 (45 degrees)
theta = 3PI/4
theta = 5PI/4
theta = 7PI/4
Do you see what the curve looks like? Now, can you start to see how to use the polar --> retangular conversion equations to express this curve in rectangular form? You will end up with two values of y for each x, it would seem.
ok thanks, when doing cos(theta) woud theta be in radians or degrees?? thanks
You can do either; that's why I listed both. It depends on the situation, but it's usually safest to just work in radians, using the fractions of PI in the arguments. Just be consistent, and check to be sure that your calculator is using the same system of angular units as you are in your head.
I just tried to sketch the curve whos form is r = cos(theta)
but there is not curve!??
when theta = 0, r = 1
when theta = (pi/2), r = 0
when theta = (pi), r = -1
ect
so there is no curve! the point I am finding are just on the x or y axis, or on the origin!
am i doing something wrong.
Well, choosing theta to be a multiple of pi/2, of course the points you get are on the x and y axes- they correspond to theta= 0, pi/2, pi, 3pi/2.
Try thet= pi/4, pi/3, pi/2, etc.
By the way, if you want to convert the equations in r and theta to x and y you might try multiplying your equation by r: r2= r + rcos(theta).
Of course, [itex]r= \sqrt{x^2+ y^2}[/itex].
As HallsofIvy says, you need to fill in more points to see the curve.
Try this -- draw a different set of axes first: draw crossed axes, with r as the vertical axis and theta as the horizontal axis. Now draw r = cos(theta) on that plot. You know, where r = 1 at theta = 0, and the curve goes to the right and comes down through 0 at theta = PI/2, then goes to -1 at theta = PI, etc., and finishes back at r = 1 when theta = 2PI. That's the traditional plot of cos(theta), right?
Now let's go back to the polar plot that you were trying to sketch -- the simplified one where r = cos(theta) without the offset of 1 yet. Picture a line in your mind on the polar plot that starts out pointing along the x axis, and pivots at the origin. You swing that line around the full circle of the polar plot, and the "r" distance of the point that you are plotting at any theta is just given by the cos(theta) number from your linear plot that you just made.
So assuming that you are right-handed, draw with your right hand on the polar plot as you move your left finger along the linear cos(theta) plot to see what the value of cos(theta) is for each theta. Mentally picture the line that pivots at the origin as it swings up and around through each angle theta, and look at the linear cos(theta) plot to see what value cos(theta) has at that angle, and plot that point on the polar plot.
What kind of figure do you get?
Now draw another linear plot, this time of 1 + cos(theta). What does that do to the linear plot? Now draw another polar sketch, this time of r = 1 + cos(theta). What did the offset of 1 do to the polar plot?
1) What is the difference between polar and cartesian coordinates?
Polar coordinates use a distance and angle to describe a point in a two-dimensional space, while cartesian coordinates use x and y coordinates to describe a point.
2) How do you convert from polar to cartesian form?
To convert from polar to cartesian form, you use the equations x = r * cos(theta) and y = r * sin(theta), where r is the distance from the origin and theta is the angle from the positive x-axis.
3) How do you convert from cartesian to polar form?
To convert from cartesian to polar form, you use the equations r = sqrt(x^2 + y^2) and theta = arctan(y/x), where x and y are the coordinates of the point.
4) What are the advantages of using polar coordinates?
Polar coordinates are useful for describing circular or rotational motion, as the distance and angle can easily represent these types of movements. They are also useful in complex analysis and engineering applications.
5) Can you graph polar coordinates?
Yes, polar coordinates can be graphed on a polar coordinate plane, also known as a polar graph. The distance from the origin is represented by the radius, and the angle is represented by the direction or rotation from the positive x-axis.
  • Precalculus Mathematics Homework Help
