• Support PF! Buy your school textbooks, materials and every day products via PF Here!
Polar curve
Find the area of the region which is inside the polar curve [tex] r =5*cos(\theta)[/tex]
and outside the curve [tex] r = 3-1*cos(\theta)[/tex]
when i plugged those two functions into my calculator and found the bounds from 1.0471976 to 5.2359878.
my integral:
[tex] \int_{1.0471976}^{5.2359878} 1/2*(5*cos(\theta))^2 - 1/2*(3-1*cos)^2[/tex]
and got a final answer of
-4.10911954 which is incorrect. anyone know what i did wrong?
AKG
2,559
You can't simply plug stuff into your calculator, then plug numbers into a formula without thinking and expect to get the right answer. The first thing you should always do is draw yourself a picture. The first fuction looks like a teardrop, with the point on the origin, and the axis of the tear drop being the x-axis, and the drop getting fatter to the right, and then rounding off. Key points (in Cartesian co-ordinates) will be (0,0) and (5,0). Also, this function will repeat its behaviour after pi. It will trace out a tear drop when theta goes from 0 to pi, and then trace over that same path again from pi to 2pi.
The second graph looks like an egg. You can think of an egg having a fat bottom and narrowing at the top. For this egg, the top will be to the left of the y-axis, and the bottom will be to the right (it's an egg lying on its side, with axis being the x-axis again). Key points: (2, 0), (0, 3), (-4, 0), (0, -3).
You should be able to see two points of intersection, one in quadrant I (x> 0, y>0), the other in quadrant IV (x>0, y<0). You know that intersection only happens when both curves have the same r values AND the same theta values, or the r value of one is the negative of the other AND the theta value of one is that plus pi of the other. You will only satisfy this condition when cos(theta) = 1/2. You should know that theta = 60 degrees here. Or you might remember that sin(30 degrees) = 1/2 and should be able to tell from this that cos(60 degrees) will be 1/2, i.e. you should never use a calculator (do they even allow to do so for tests anyways?) You can easily change 60 degrees into radians. Also, if cos(theta) is positive (like 1/2), then you can find values in quadrants I and IV for theta, so your other point of intersection will occur at -60 degrees.
Actually, you don't need that other point of intersection. You should see by symmetry that you can find the area by finding 2 x another area, where theta goes from 0 to pi/2. From 0 to pi/3, you will find the area under the second curve, and from pi/3 to pi/2, you will find the area under the first curve. Sum these, multiply by 2 and get your answer.
You can and should do this all without a calculator, and I can't imagine how you could do this without drawing pictures and thinking about it and just using a calculator. You should draw a picture, and verify the statements I've made:
1) The first fuction looks like a teardrop, with the point on the origin, and the axis of the tear drop being the x-axis, and the drop getting fatter to the right, and then rounding off. Key points (in Cartesian co-ordinates) will be (0,0) and (5,0).
2) The second graph looks like an egg. You can think of an egg having a fat bottom and narrowing at the top. For this egg, the top will be to the left of the y-axis, and the bottom will be to the right (it's an egg lying on its side, with axis being the x-axis again). Key points: (2, 0), (0, 3), (-4, 0), (0, -3).
3) You should be able to see two points of intersection, one in quadrant I (x> 0, y>0), the other in quadrant IV (x>0, y<0).
4) You know that intersection only happens when both curves have the same r values AND the same theta values, or the r value of one is the negative of the other AND the theta value of one is that plus pi of the other.
5) You will only satisfy this condition when cos(theta) = 1/2. Note you are satisfying two conditions here with cos(theta), the first one where r and theta values are the same, the second where they are opposite (and you should be able to see why theta is the opposite of pi + theta)
6) You should see by symmetry that you can find the area by finding 2 x another area, where theta goes from 0 to pi/2
7) From 0 to pi/3, you will find the area under the second curve, and from pi/3 to pi/2, you will find the area under the first curve.
Related Threads for: Polar curve
  • Posted
  • Posted
  • Posted
  • Posted
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
