Polar equation problems
  • Thread starter rjs123
[tex] r = \theta + sin(2\theta)[/tex] for [tex] 0 \le \theta \le \pi [/tex]
a. Find the area bounded by the curve and the x-axis
b. Find the angle [tex]\theta[/tex] that corresponds to the point on the curve with x-coordinate -2
c. For [tex]\frac{\pi}{3} < \theta <\frac{2\pi}{3} , \frac{dr}{d\theta}[/tex] is negative. What does this fact say about r? What does this fact say about the curve?
d. Find the value of [tex]\theta[/tex] in the interval [tex] 0 \le \theta \le \frac{\pi}{2}[/tex] that corresponds to the point on the curve in the first quadrant with the greatest distance from the origin.
a. [tex]1/2\int_{0}^{\pi }(\theta + sin2\theta)^2 d\theta}[/tex]
When I foil I end up with [tex] \theta^2 + 2\theta\sin2\theta + sin^2(2\theta)[/tex]
this is the part where I believe I made the mistake. I know the area is 4.9348 by the use of my calculator...if it is indeed correct...I can easily integrate the 1st and 3rd term...but i think the second term needs to be done by parts if im not mistaken.
Answers and Replies
Parts should be ok to solve that. It's pretty straight forward. If you're familiar with the "ultra-violet voodoo" pneumonic, then let the [tex]\theta[/tex] term be the "doo" (du) part.
i seem to be having trouble doing the integration by parts
[tex] 2\theta\sin2\theta[/tex]
using uv - [tex]\int[/tex] vdu
u = 2[tex]\theta[/tex] dv = [tex]sin2\theta[/tex]
du = 2[tex]d\theta[/tex] v = [tex]\frac{-1}{2}cos2\theta[/tex]
[tex]-\theta\cos2\theta + 1/2sin2\theta[/tex]
the final integral from [tex] \theta^2 + 2\theta\sin2\theta + sin^2(2\theta)[/tex] becomes:
[tex]\frac{1}{3}\theta^3-\theta\cos2\theta+ 1/2sin2\theta + \frac{1 - cos4\theta}{2}[/tex]
from 0 to [tex]\pi[/tex]
Try
[tex]u=2\theta[/tex]
[tex]\Rightarrow du=2d\theta[/tex]
[tex]v=\sin 2\theta[/tex]
[tex]\Rightarrow dv=-2\cos 2\theta[/tex]
Then plug into your expression of
[tex]uv-\int v du[/tex]
Don't forget to evaluate that first part with limits.
Try
i'm pretty sure dv = sin2[tex]\theta[/tex]
and its integral v = -1/2cos2[tex]\theta[/tex]
Yes, you're correct. But it is of no consequence because we don't need the differential of v.
Wait. Hang on. No.
[tex]dv=-(1/2)\cos 2\theta d\theta[/tex]
Wait. Hang on. No.
you set u to one part, and dv to another
du is the differential of u,
v is the integral of dv.
I'll work on this tomorrow...ahhhh so frustrating.
any help at integrating this?
Related Threads on Polar equation problems
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
11K
  • Last Post
  • Last Post
  • Last Post
