Homework Help: Polar Integral
  1. Apr 16, 2015 #1
    ∫∫dydx
    Where the region Ω: 1/2≤x≤1 0 ≤ y ≤ sqrt(1-x^2)
    2. Relevant equations
    3. The attempt at a solution
    The question asked to solve the integral using polar coordinates. The problem I have is getting r in terms of θ. I solved the integral in rectangular ordinates using a trig sub and found the answer to be (π/6) - (√3)/8.
    Thanks for all input.
  3. Apr 16, 2015 #2
    LCKurtz
    Have you drawn a picture? Remember ##r## goes from ##r## on the inner curve to ##r## on the outer curve. What is the equation of ##x = \frac 1 2## in polar coordinates? What is the equation of the circle? And from the picture you should be able to see the ##\theta## limits.
  4. Apr 16, 2015 #3
    Mark44
    Staff: Mentor
    You're not solving an equation -- you're setting up and evaluating an integral
    The integrand is pretty straight forward; probably the hardest part is figuring out the limits of integration. A ray extending out from the pole (0, 0) goes through the vertical line, x = 1, to the circle. Convert the equation of the vertical line to polar from. The circle part is simple.
  5. Apr 16, 2015 #4
    I have drawn the picture and it is very straightforward. The problem I am having is that the radius is not constant so i need to get r in terms of theta. http://www5b.wolframalpha.com/Calculate/MSP/MSP17811i1c25cda73i33d700001h169b9cb5h0603d?MSPStoreType=image/gif&s=34&w=200.&h=193.&cdf=Coordinates&cdf=Tooltips [Broken]
  6. Apr 16, 2015 #5
    LCKurtz
    OK, so you have drawn the picture. Now answer the questions I asked in my reply above.
  7. Apr 16, 2015 #6
    SammyS
    Staff Emeritus
    Do you know how to express x in terms of r and θ ?
  8. Apr 16, 2015 #7
    As in x=rcos (θ) and y=rsin (θ) ?
  9. Apr 16, 2015 #8
    SammyS
    Staff Emeritus
    Good the left hand boundary of the region is x = 2.
    That should give you a relation in terms of r and θ for that boundary.
    The right hand boundary (curved boundary) should be easy in terms of r .
  10. Apr 16, 2015 #9
    LCKurtz
    You mean ##x = \frac 1 2##.
  11. Apr 16, 2015 #10
    SammyS
    Staff Emeritus
    Right!
  12. Apr 17, 2015 #11
    Ok so using the conversion I found the bounds of r from (1/2)sec(θ) to 1
    Thanks for the input
  13. Apr 17, 2015 #12
    SammyS
    Staff Emeritus
    Yes. You're welcome.
  14. Apr 17, 2015 #13
    LCKurtz
    And what bounds did you get for ##\theta##?
Have something to add?
Draft saved Draft deleted
