1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Polarization of Light
  1. May 4, 2014 #1
    Unpolarized light of intensity Io is incident on two polarizing sheets whose axes are perpendicular.
    A) what is the intensity of the light after the first sheet?
    B) what is the intensity of the light after the second sheet?
    2. Relevant equations
    I=(Imax)cos^2(Θ)
    3. The attempt at a solution
    A) I thought the intensity would not change since you need two polarizing sheets at certain angles to change the intensity.
    B) Intensity is 0? If I plug 90° into the relevant equation, I=0 since cosine at 90 degrees is zero.
    Would I be correct in my steps?
  3. May 4, 2014 #2
    Yeah, two linear polarizers tilted at 90 degrees relative to each other will absolutely (or nearly absolutely) block all light from reaching the observer at the other end.
  4. May 4, 2014 #3
    Okay thank you! And what about the one sheet? Would I be correct in saying that it would not have any effect regardless of the angle?
  5. May 4, 2014 #4
    There would be some reduction in intensity with one polarizer.
Have something to add?
Draft saved Draft deleted
Similar Discussions: Polarization of Light
  1. Polarization of light (Replies: 5)
  2. Polarized Light (Replies: 3)
  3. Polarization of light (Replies: 3)
  4. Polarization of Light (Replies: 7)
  5. Polarization of light (Replies: 1)
Loading...
