Designing a Pole Climbing Robot for Mechanical Engineering: A Step-by-Step Guide
In summary, Salimshk's idea for a robot to climbing a pole to a height of 5m and then carrying a load of 5 bricks sounds like it could be done with some modifications. A motorized wheelchair would be a good starting point, and would likely require no re-invention.
salimshk
Pole Climbing Robot, Please Help!?
Hi, I have been given a project for Mechanical Engineering 1st year. We have been given no ideas and I cannot go to the lecturers for any help and I do not have any previous knowledge even on the basics.
Guidlines are as follows:"Design an robot capable of climbing a standard scaffolding pole to a height of 5m while carrying a
load of 5 standard size engineering bricks. It must automatically stop at a height of 5m, then wait 30
seconds during which the bricks are manually removed before automatically reversing and finally
stopping at the bottom"
2. Homework Equations
3. The Attempt at a Solution
My initial ideas are four very high friction wheels incorporated into a sort of 'ring' that clamps around the scaffolding pole and some sort of tray with a hole to accommodate for the pole which attaches on top of this ring to carry the bricks. I haven't even thought about motors or any electronics as of yet, but how does this idea sound to you guys? Is it possible for the wheels to provide enough friction to withstand the weight of 5 bricks?
Welcome to PF, Salimshk.
Your idea sounds fine to me, but possibly more complex than is necessary. The initial conditions don't seem to indicate that you can't damage the pole. If that's the case, then my first approach would be to use a couple of 'idler' wheels for placement, and something like a large saw blade for traction.
I don't mean 'large' in the sense that a professional sawyer would think of it; more like 8"-10" diameter that you would use for a radial-arm saw at home.
Re-inventing the wheel is not necessary. Simply perfecting an existing design will get you an "A". Here is a design you could start with:
http://www.nydailynews.com/lifestyle/2009/09/02/2009-09-02_photo_of_poledancing_doll_has_parents_in_an_outrage.html
All kidding aside, congrats to you for having placed yourself in a position to further your education. The sky's the limit! Enjoy the ride! :wink:
I retract my previous answer, having re-read the question. When I see the word 'pole', I automatically think of wood. Around here, though, standard construction scaffolding is made of steel. Nix the saw blade idea. You should still be able to get by with 3, rather than 4, wheels (rollers, whatever).
I have a few motors from electric wheelchairs that would do the trick. They're 12VDC 1/2hp units with worm-drive gearheads. Each has 2 separate field coils which can be connected in parallel for huge torque, or in series for less torque and double the speed.
If you can get your mitts on one of those, Bob's your uncle. You could also look into something made for a power-scooter or golf cart, or even an automotive starter.
If the rules don't stipulate otherwise, consider leaving the battery on the ground and using a long flex cable for power. That will significantly cut down on the weight that you have to lift.
1. What is a Pole Climbing Robot?
A Pole Climbing Robot is a type of robot designed to climb vertical poles or structures. It is equipped with specialized gripping mechanisms and sensors to navigate and climb the pole.
2. What is the purpose of a Pole Climbing Robot?
The main purpose of a Pole Climbing Robot is to perform tasks that are difficult or dangerous for humans to do, such as inspecting power lines or conducting repairs on tall structures. It can also be used for surveillance and other industrial applications.
3. How does a Pole Climbing Robot work?
A Pole Climbing Robot typically uses a combination of gripping mechanisms, sensors, and motors to climb the pole. The gripping mechanisms provide traction and stability, while the sensors help the robot to navigate and avoid obstacles. The motors are used to move the robot up and down the pole.
4. What are the benefits of using a Pole Climbing Robot?
There are several benefits to using a Pole Climbing Robot. These include increased safety for workers, reduced maintenance costs, and improved efficiency in completing tasks. The robot can also access areas that are difficult for humans to reach, making it a valuable tool in various industries.
5. What are the challenges in developing a Pole Climbing Robot?
Developing a Pole Climbing Robot can be challenging due to the complex nature of climbing and navigating vertical poles. Some of the main challenges include designing effective gripping mechanisms, ensuring stability and balance, and developing precise sensors and control systems. Additionally, the robot must be able to withstand various environmental conditions, such as extreme temperatures and strong winds.
  • Mechanical Engineering
10K
  • STEM Academic Advising
