Homework Help: Poles and Zeroes of a system
  1. Feb 12, 2015 #1
    I am trying to understand what is meant by "poles can be used to obtain the form of the system response''
    This is an example for a transfer function (s+2)/(s+5) and a step function input
    http://postimg.org/image/97vnos9uz/
    2. Relevant equations
    3. The attempt at a solution
    For example, the input pole of s=0 generates the form of the forced response.
    I don't understand what s=0 has to do with the output transform (2/5)/s and the time response of 2/5
  3. Feb 12, 2015 #2
    vela
    Staff Emeritus
    Education Advisor
    Recall when you solved differential equations like ##y'' + 5y' + 6 = 0##. By substituting a solution of the form ##y=e^{rt}##, you obtained the characteristic equation ##r^2 + 5r + 6 = 0##. After you obtain the roots, you could write down that the solution to the differential equation was ##c_1 e^{-2t} + c_2 e^{-3t}##.
    The transfer function is the impulse response of the system. That is, it's the solution to ##y'' + 5y' + 6 = \delta(t)##. If you take the Laplace transform of both sides, you end up with ##(s^2+5s+6)Y(s) = 1##. Solving for Y(s), you get
    $$Y(s) = \frac{1}{s^2+5s+6}.$$ Note that the denominator is identical to the characteristic polynomial, so if you know poles of the transfer function, which are the roots of the characteristic polynomial, you know what terms are going to show up in the homogeneous part of the system response.
Have something to add?
Draft saved Draft deleted
