Constructing a Polynomial for the Sum of Square Roots - Degree 4 Homework
In summary, a polynomial of degree 4 is a mathematical expression with four terms that contain variables raised to the power of four or lower. The highest power of the variable in a polynomial of degree 4 is 4, and the degree of the polynomial is also 4. This means that the polynomial has up to four solutions, which can be found by substituting values for x and calculating the corresponding y values. To graph a polynomial of degree 4, you can plot points or use technology, such as a graphing calculator.
happyg1
308
Let R be the field of real numbers and Q the field of rational numbers. In R,[tex]\sqrt 3 [/tex] and [tex]\sqrt 2[/tex] are both algebriac. Exhibit a polynomial of degree 4 staisfied by[tex]\sqrt 2 + \sqrt 3 [/tex].
I attempted to construct this by [tex](\sqrt 2 + \sqrt 3)^4 = 20\sqrt 6 + 49[/tex]
then my polynomial is [tex] x^4-(20\sqrt 6 + 49)=0[/tex]
is this even close? ThenI have to show it's irreducible and I'm not quite sure where to start that.
My next problem is to prove that sin 1 is an algebriac number. I'm not sure how to construct that polynomial to prove it's irreducible, either.
Any hints or advise will be appreciated
Thanks
CC
Dear CC,
Great job on constructing a polynomial that satisfies \sqrt 2 + \sqrt 3! Your polynomial is indeed close, but it can be simplified further. Remember that (\sqrt 2 + \sqrt 3)^4 = (2 + 2\sqrt 6 + 3\sqrt 2 + 3\sqrt 3)^2 = (5 + 4\sqrt 6)^2 = 25 + 40\sqrt 6 + 24 = 49 + 40\sqrt 6. So your polynomial can be written as x^4 - (49 + 40\sqrt 6) = 0. This polynomial is irreducible because it has no rational roots and cannot be factored into polynomials of lower degree with rational coefficients.
For proving that sin 1 is an algebraic number, we can use the fact that sin x is a solution to the polynomial equation x - (1 - \cos x) = 0. Substituting x = 1, we get sin 1 = 1 - \cos 1. Now we can use the fact that cos x is a solution to the polynomial equation x^2 - 2 = 0. Substituting x = 1, we get \cos 1 = \sqrt 2 - 1. So sin 1 = 1 - (\sqrt 2 - 1) = 2 - \sqrt 2. Therefore, the polynomial x - (2 - \sqrt 2) = 0 has sin 1 as a root, making sin 1 an algebraic number.
I hope this helps! Let me know if you have any further questions or need clarification.
What is a polynomial of degree 4?
A polynomial of degree 4 is a mathematical expression that contains four terms with variables raised to the power of four or lower. It can be written in the form of ax^4 + bx^3 + cx^2 + dx + e, where a, b, c, d, and e are constants and x is a variable.
What is the highest power of the variable in a polynomial of degree 4?
The highest power of the variable in a polynomial of degree 4 is 4. This means that the variable is raised to the power of 4 in one of the terms in the polynomial.
What is the degree of a polynomial of degree 4?
The degree of a polynomial of degree 4 is 4. The degree of a polynomial is determined by the highest power of the variable in the expression.
How many solutions does a polynomial of degree 4 have?
A polynomial of degree 4 can have up to four solutions, depending on the number of distinct roots. However, some of the solutions may be repeated or complex numbers.
How do you graph a polynomial of degree 4?
To graph a polynomial of degree 4, you can plot points by substituting different values for x and calculating the corresponding y values. You can also use technology, such as a graphing calculator, to plot the graph accurately.
