juantheron
- 247
- 1
If $p(x)$ be a polynomial of degree $98$ such that $\displaystyle p(x) = \frac{1}{x}$ for $x=1,2,3,...,98$
Then value of $p(100)=$
jacks said:If $p(x)$ be a polynomial of degree $98$ such that $\displaystyle p(x) = \frac{1}{x}$ for $x=1,2,3,...,98$
In that case, let $q(x) = xp(x)-1$. Then $q(x)$ is a polynomial of degree 99, and $q(x)=0$ for $x=1,2,3,\ldots,99$. By the factor theorem, $q(x) = k(x-1)(x-2)\cdots(x-99)$ for some constant $k$. Also, $q(0)=-1$, and therefore $k=1/99!$. It follows that $q(100) = 1$, from which $p(100) = 1/50$.If $p(x)$ be a polynomial of degree $98$ such that $\displaystyle p(x) = \frac{1}{x}$ for $x=1,2,3,...,\color{red}{99}$
A polynomial of degree 98 is an algebraic expression that consists of variables, constants, and mathematical operations such as addition, subtraction, multiplication, and exponentiation. The highest exponent of the variable in the polynomial is 98.
To find the value of a polynomial of degree 98 at a specific point, you can substitute the given point in place of the variable and then simplify the expression using the order of operations. For example, to find the value of p(100), you would substitute 100 for the variable in the polynomial p(x) and then simplify the resulting expression.
The degree of a polynomial indicates the highest exponent of the variable in the expression. This value helps determine the behavior and characteristics of the polynomial, such as the number of possible solutions and the end behavior.
Yes, a polynomial of degree 98 can have more than one solution. The number of solutions depends on the behavior of the polynomial and the number of times it crosses the x-axis. A polynomial of degree 98 can have a maximum of 98 real solutions.
The value of a polynomial of degree 98 at a specific point can be used in various real-life applications, such as modeling population growth, predicting stock market trends, and calculating interest rates. It can also be used to solve complex engineering and physics problems.
