Polytropic Process: Finding Final Pressure and Volume
In summary, a frictionless piston cylinder contains ideal gas hydrogen with properties of R = 4.125 KJ/Kg.K and γ= 1.4. The gas undergoes a polytropic process with n = 1.22 from an initial pressure of 100 Kpa, temperature of 765 C, and volume of 0.35 m3 until reaching a final volume of 8.0 m3. To find the mass of the gas and final pressure and volume, the equation PVn = constant can be used.
Mohd17
A frictionless piston cylinder contains ideal gas hydrogen , R = 4.125 KJ/Kg.K , initially at p1=100 Kpa , t1 = 765 C , V1 = 0.35 m3 . The gas undergoes a polytropic process with n = 1.22 until the final volume becomes V2=8.0 m3
Cp = 14.3338 , Cv= 10.2043 , [URL]http://www.taftan.com/thermodynamics/GAMMA.GIF[/URL] = 1.4
Find :
a) Mass of the ideal gas
b) Final pressure and volume of the gas
You need to post your attempt.
What relevant equations do you think are needed here?
the problem how can i get the volume of the gas !
already i get the answers for part a and the final pressure
You should know for a polytropic process PVn = constant.
sorry but i didin't understand ...
now what's the answer ?
PVn = constant means that
P1V1n = P2V2n
You were given P1, V1, n and you found P2.
1. What is a polytropic process?
A polytropic process is a thermodynamic process in which a system undergoes a change in its state, while the relationship between pressure and volume remains constant. This means that the system follows a specific path on a pressure-volume diagram, known as a polytropic curve.
2. What is the equation for a polytropic process?
The equation for a polytropic process is given by: P1V1^n = P2V2^n, where P1 and V1 are the initial pressure and volume, P2 and V2 are the final pressure and volume, and n is the polytropic index.
3. What is the polytropic index?
The polytropic index, denoted by n, is a measure of the relationship between pressure and volume during a polytropic process. It is equal to the ratio of specific heats (γ) of the gas, and is often used to characterize the behavior of a gas during a polytropic process.
4. What are some real-life examples of polytropic processes?
Some real-life examples of polytropic processes include the compression or expansion of a gas in a piston-cylinder system, the compression or expansion of air in a turbocharger, and the compression or expansion of gas in a gas turbine. Polytopic processes can also occur in the human body, such as during breathing or blood circulation.
5. How is a polytropic process different from other thermodynamic processes?
A polytropic process differs from other thermodynamic processes in that it maintains a constant relationship between pressure and volume throughout the process. This means that the work done and heat transferred during a polytropic process can be calculated using the same equation, unlike other processes such as isothermal or adiabatic processes.
