Homework Help: [PoM] Electron gas pressure
  1. Nov 26, 2016 #1
    BRN
    Hi guys! I have a problem with this exercise:
    The stars called white dwarfs may have inside them a density in order of 1011 kg m-3. For semplicity, we assume:
    • these stars are made with non interacting protons and electrons at the same quantity and with uniform density;
    • Inside, the electrons are relatevistic with energy ε=c|p|=cħ|k|;
    • Temperature is nothing.
    In these hypotheses is evaluated the pressure exerted by this electron gas.
    3. The attempt at a solution
    I'm at T=0, but electrons are relatevistic, so P=-∂U/∂V.
    Internal energy is:
    U=∫0εFg(ε)ε dε
    where:
    states density g(ε)=(2me3/2V√ε)/(√2π2ħ3)
    ε=ħck ; k2=p22=me2v22=2εme2 ⇒ k=√(2εme2)
    Then:
    U=∫0εF (2me3/2V√ε)/(√2π2ħ3) √(2εme2) ħc dε =
    = (me3/2V c εF3/2 √(εFme))/(π2ħ2)
    So:
    P=-∂U/∂V=-(me3/2 c εF3/2 √(εFme))/(π2ħ2)
    Fermi energy is:
    εF2/(2me)(3π2N/V)2/3
    Then:
    P=-3/4ħ2c(3π2)1/3(N/V)4/3
    This solution is wrong. The correct solution is:
    P=(ħ c(3π2)1/3(N/V)4/3)/4
    Could someone tell me where I'm wrong?
  3. Nov 26, 2016 #2
    TSny
    2017 Award
    This is not the correct density of states for this problem. You will need to derive the expression for g(ε) based on the assumption that ε = c|p|.
  4. Nov 28, 2016 #3
    BRN
    I checked on my book and for fermions and low temperature, the density of states is:
    $$ g(\epsilon)=\frac{(2m_{e})^{3/2}V2}{4\pi^{2}\hbar^{3}}\epsilon^{1/2} $$
    but replacing ε with $$ \hbar c \sqrt{\frac{2m_{e}\epsilon}{\hbar^{2}}} $$ solution is wrong again...
    How to calculate the relativistic density of states?
  5. Nov 28, 2016 #4
    TSny
    2017 Award
    This is for the nonrelativistic case. You need the highly relativistic case.
    You can just repeat the derivation for the nonrelativistic case, but use the highly relativistic formula E = cp for the energy of an electron. Here is a link that derives the nonrelativistic case.
    http://web.eecs.umich.edu/~fredty/public_html/EECS320_SP12/DOS_Derivation.pdf
    The derivation for the relativistic case is the same up through equation 4b. You will need to modify the rest of the derivation.
  6. Nov 29, 2016 #5
    BRN
    I don't understand... :(
    I start with:
    $$ g(k)dk=\frac{Vk^{2}}{\pi^{2}}dk $$
    and:
    $$ \epsilon=c\hbar k \Rightarrow k=\frac{(\epsilon-\epsilon_{c})}{c\hbar} \Rightarrow dk=\frac{d\epsilon}{c\hbar} $$
    then:
    $$ g(k)dk=\frac{V(\frac{\epsilon-\epsilon_{c}}{c\hbar})^2}{\pi^2}\frac{d\epsilon}{c\hbar}\Rightarrow g(\epsilon)d\epsilon=\frac{(\epsilon-\epsilon_{c})^2}{c^3\pi^2\hbar^3}d\epsilon $$
    $$ \frac{(\epsilon-\epsilon_{c})^2}{c^3\pi^2\hbar^3} $$
    but ## \epsilon_{c}=?? ##
  7. Nov 29, 2016 #6
    TSny
    2017 Award
    Just set ##\epsilon_c## to zero. ##\epsilon_c## comes from dealing with electrons in the conduction band of a solid.
    From ##\epsilon = cp = c \hbar k##, you can see that ##k = \frac{\epsilon}{c \hbar}##. So, use that rather than ##k = \frac{\epsilon - \epsilon_c}{c \hbar}##.
    Your work looks good, but did you drop a factor of ##V## near the end?
  8. Nov 30, 2016 #7
    BRN
    I'm lost... :(
    whith ##\epsilon_{c}=0##
    $$ U=\int_{0}^{\epsilon_{F}} g(\epsilon)\epsilon d\epsilon=\int_{0}^{\epsilon_{F}} \frac{\epsilon^2}{c^3\pi^2\hbar^3} c \hbar \frac{\epsilon}{c \hbar}d\epsilon=\frac{\epsilon_{F}^4}{4c^3\pi^2\hbar^3}$$
    $$ \epsilon_{F}=\frac{\hbar^2}{2m_{e}}(3 \pi^2\frac{N}{V})^{2/3} $$
    then
    $$ U=\frac{\hbar^5}{4c^32^4m_{e}^4}3^{8/3}\pi^{10/3}(\frac{N}{V})^{8/3} $$
    $$ P=-\frac{\partial U}{\partial V}=\frac{\hbar^5}{8c^3m_{e}^4V}(3\pi^2)^{5/3}(\frac{N}{V})^{8/3} $$
    a disaster...
    in order to pass from g(k) to g(ε) i need to divide for V...
    please do not hate me!!!
  9. Nov 30, 2016 #8
    TSny
    2017 Award
    This looks good. But I don't understand why there isn't a factor of ##V##, unless ##U## represents the total energy per unit volume. In your first post, your expression for ##U## for the nonrelativistic case does have a factor of ##V##.
    This is the Fermi energy for the nonrelativistic case. You will need to derive it for the extreme relativistic case. Hint: What does ##\int_0 ^ {\epsilon_F}g(\epsilon) d\epsilon ## represent?
    Why is that?
    Of course not. Hang in there. :woot:
  10. Dec 1, 2016 #9
    BRN
    Ok, here we go!
    I took possession of my mental faculties.:smile:
    The number of k states within in spherical shell is:
    so
    $$ \epsilon=c\hbar k \Rightarrow k=\frac{\epsilon}{c\hbar} \Rightarrow dk=\frac{d\epsilon}{c\hbar} $$
    Now, the relativistic density of the states come from:
    $$ g(k)dk=\frac{V(\frac{\epsilon}{\hbar c})^2}{\pi^2}\frac{d\epsilon}{\hbar c}=\frac{V\epsilon^2}{\pi^2\hbar^3 c^3}d\epsilon $$
    With the number of particles within the sphere of radius ## \epsilon_{F} ##, is possible to calculate the Fermi energy:
    $$ N=\int_{0}^{\epsilon_{F}} g(\epsilon) \epsilon d\epsilon=\int_{0}^{\epsilon_{F}}\frac{V\epsilon^2}{\pi^2\hbar^3 c^3}d\epsilon=\frac{V\epsilon_{F}^3}{3\pi^2\hbar^3 c^3}\Rightarrow\epsilon_{F}=\hbar c\sqrt[3]{\frac{3N\pi^2}{V}} $$
    Then, the internal energy is:
    $$ U=\int_{0}^{\epsilon_{F}} g(\epsilon) \epsilon d\epsilon=\int_{0}^{\epsilon_{F}}\frac{V\epsilon^2}{\pi^2\hbar^3 c^3}\hbar c \frac{\epsilon}{\hbar c}d\epsilon=\frac{V\epsilon_{F}^4}{4\pi^2\hbar^3 c^3}=\hbar c\frac{(3N)^{4/3}\pi^{2/3}}{4V^{1/3}} $$
    In the end, the pressure is
    $$ P=-\frac{\partial U}{\partial V}=\frac{\hbar c}{4}(3\pi^2)^{1/3}(\frac{N}{V})^{4/3} $$
    The star is made of by protons and electrons in same quantity, that is made of by idrogen. Then:
    $$ \frac{N}{V}=N\frac{\rho N_{A}}{A10^{-3}}=6.0221*10^{37}[m^{-3}]\Rightarrow P=5.7713*10^{24}[Pa] $$
    It was not difficult this exercise!
    I have to stop studying at night...:frown:
    Tanks very much, your help was crucial!:wink:
  11. Dec 1, 2016 #10
    TSny
    2017 Award
    OK. Good work!
Have something to add?
Draft saved Draft deleted
