DaveC426913
- 6,106
I have been planning a heat exchanger for my pool for quite some time. I'd like some reco's about pressures and pipe diameters.
See attached diagram.
The pool hose is 1 1/4" flexible PVC hose like this:
[URL]http://www.poolsupplies.com/images/products/tn_105550.jpg[/URL]
The pump is a standard Hayward 1/4 or 1/2 HP that generates somewhere around 20-40psi.
It seems to me (and the pool expert who gave me the idea) that I should be able to use one of these saddle valves:
[URL]http://img.diynetwork.com/DIY/2003/09/17/r107_1fb_lead.jpg[/URL]
and some flexible aquarium or other rubber tubing.
Some questions:
Some questions:
- Can I get a saddle valve for a 1 1/4" flexible PVC pipe?
- At 20-40 psi, will the saddle valve still be water-tight?
- What diameter tubing for the heat exchanger would be a good compromise between volume/throughput and surface area/heat exchange?
1/4"? 3/8"? What's good? - I'll need a pressure differential to get the water flowing through the exchanger. Where? (see 1 and 2 in diagram) I'm sure 1 will work. Will 2 work? I mean, I'm adding water back into the input. Does that compromise total throughput?
- Do I have to worry about whether the exchanger tubing will burst?
