What is the true nature of randomness and its implications in finance?
In summary, randomness can be defined as a word that is defined in terms of a negative, such as "unkind" or "antisocial." It is often described in terms of what it is not, such as having no history, dependence on initial conditions, pattern, or predictable order. In probability theory, a "random variable" is a function that assigns a real number from 0 to 1 to each "event" of a measure space. In complexity theory, the "Kolmogorov complexity" of a string can be used as a measure of randomness, as incompressible strings have no distinguishing features. However, this system only applies in bulk and cannot be used to talk about individual strings. Some argue that chaotic
  • #36
Why aren't all events random? causes are never observable or experienced. they are just explanations. One never sees a cause. We live in a fantasy world where we think just because our minds are able to organize experience that there are actual causes outside of our minds.
Isn't each day's sunrise random, unconnected to anything except itself?
  • #37
wofsy said:
So give me an example.
See post 24 on things like quantum zeno and coin tossing.
  • #38
I still don't get it. the global constraint in a coin toss does not at all tell you that the outcomes will be random.
Furthermore constraints eliminate randomness. So why don't constraints actually create determinism?
  • #39
In what way does the carefully determined circumstances of a coin toss not produce a random outcome?
Oh, you mean that you want to know whether the randomness is "real". Whether it "exists" and is not merely a product of arranged circumstances.
The global system of constraint may not know the particular outcome, but some other imaginary observer could do it differently and track the physics of the spinning all along the way with sufficient accuracy.
Constraints eliminate degrees of freedom. They suppress what can happen at a locale. But then any degrees of freedom that are not eliminated, by definition, will be expressed. And the more degrees removed, the more visible - meaningful or informational in terms of the system set-up - will be those remaining free actions.
So as I say, toss a ball and the act is so unconstrained that the side it lands on seems pretty meaningless. Toss a coin and now its choice of landings is so constrained that up-down becomes a remarkably arbitrary-looking freedom. It becomes an "event" rather than the non-event of a ball toss. And it becomes "random" in being predictably unpredictable. Where again, with a ball toss, which "way up" the ball falls is so unremarkable as to be vague - neither here nor there.
You can agonise forever whether local events that are the product of constraints are really determined or really free. The question is meaningful only in relation to the context, the system, that is producing those events.
You can insert a laplacean demon into the scenario to try to clarify matters. But positing a micro-observer to bypass the macro-context is not going to answer your ontic question (though it is a useful way to explore the limits of an information theoretic modelling approach).
  • #40
I see what you are saying. I was just asking why constraining the coin to a two sided toss should produce randomness. It doesn't follow in my mind. Why couldn't it be entirely deterministic?
  • #41
Also it seems to me that what part of the ball hits the ground is also random - it's distribution is uniform across its entire surface. The coin toss is less random since it can only have 2 outcomes.
  • #42
You don't see what I'm saying as you insist on asking which local view is "the real" - the random event or the determined event.
The point is that it is the dynamics of the system that create this difference. It is the choice of the system that is real. Random and determined would be two ends of a spectrum of choices the system could make. The complementary limits.
So a coin toss could be asymptotically random or asymptotically determined. You could even toss a coin as if you didn't care, then record the toss with super-sensitive instruments that in fact from initial conditions and Newtonian mechanics - and all sorts of constraints over the environment which are the standard gear of experimentation - could give a deterministic account of why a particular toss came up heads or tails.
You can then argue endlessly about which is the real picture of causality at the local scale. But you can see that the causality is in fact very different at the global scale. The flip-flop from don't care to do care.
In physics, it is normal to discard global facts. But in philosophy, they are what you need to remember about the "truth" of the total situation.
A coin toss is of course just a way into these thorny issues. Then you can go on to talk about QM and chaos - areas where nature itself is the system.
  • #43
Not sure that I can simplify matters for you much further.
Imagine a perfect sphere landing on a perfect plane and resting on only a single point. You can see there would indeed be an infinity of "sides". Outcomes don't come less unconstrained and therefore less distinctive. More vague and less of a crisp event.
A binary choice is then the opposite, the most distinctive and constrained form of choice. Hence why all information theory boils down to the crisp black and white of binary codes.
Perhaps you should offer us your personal definition of random.
A lot of people talk about it as meaning uncaused events. I never said anything about a lack of causality. Instead I was talking about where to look to find the missing causality.
  • #44
this just seems wrong. Where the ball lands is not vague. The ball toss is not a non-event and it is no less random than the coin toss. perhaps you should tell me what you mean by random.
  • #45
No, after you. Why not start by better explaining why efficient markets would actually produce random prices, the example you introduced.
  • #46
i actually thought I gave a good explanation. It is not original to me. It is standard. I could go into the mathematics more if you want. I would be glad to do that. Let me know.
  • #47
I'm familiar with the maths and also the literature arguing other models like fractals may be better.
What we are discussing here is the why behind the what. So why do actors with perfect information result in random statistics? I'll give you a clue. It is about local independent choice permitted within global economic contexts - markets, indeed. But I'll let you give your view first.
  • #48
Your language is difficult for me to penetrate. And because of this I am not sure what to say.
Certainly in the QM course I took, randomness was considered intrinsic to measurement. The whole theory seems based on it. I read your Zeno effect reference and this does not seem to change this. It would help me if you could elaborate on this article to say why it does.
As far as markets go, it is simply that information is processed completely and incorporated into prices. the price can not change until new information arises. Since new information is unknowable today - otherwise it wouldn't be new - the market price must be a Martingale. this fact does not require any model of how new information appears. This idea has nothing to do with the ideas of fractal or chaos. And most market mathematicians that I know do not believe that the market exhibits chaos.
  • #49
Yes, the superficial explanation is obvious. But it is the deeper commonalities we were discussing.
So a requirement here is a collection of independent traders. And this in turn requires a context of constraints that can produce such crisp local independence.
Although the machinery of markets - the necessary infrastructure - being human-made rather disguises this fact. It is constructed like all machines. So you would have to look beyond that to the sociology that creates the blueprint for the market machinery.
You have to remember that models are convenient fictions. They leave out unnecessary details as much as possible. But when you want to step back to the grander philosophical view, you want to think about exactly what facts have been suppressed.
  • #50
the traders do not have to be independent, They only need to incorpaorate information efficiently and quickly. There is no assumption whatsoever of independence. This is not a convenient fiction.
  • #51
Rubbish. Completely different statistics would result if traders were highly correlated in their actions.
The very fact that all the traders are forced to make decisions at the same moment means there is no time for the communication that would create long scale correlations. The speed of trading is what isolates them. Disappointing that you are not thinking any of this through for yourself.
Check out Wisdom of the Crowds for a pop primer on these kinds of issues. Or Strogatz's Sync.
You've got to get in behind the textbook models to discover what the models presume (what is implicit rather than explicitly represented).
  • #52
Traders are highly correlated - I was a trader myself. But I think this discussion is fruitless. It has no rigor and I can not sink my teeth into anything that you are saying. I am not smart enough to figure out even the first thing that you are trying to say. I am sorry. I really tried.
  • #53
So you were a quant until the vodoo economics came home to roost? I have had a lot of fun discussing Fama/French, portfolio theory and other such stuff with fund managers over the past few years, watching that good old quadrillion dollar derivatives bubble inflate as they framed their bets in gaussian standard deviation errors. Linear thinking in a non-linear world they were busy creating.
Talk about local independence - as in a lack of suitable intelligent global constraints. No fool would have allowed the derivative markets to operate the way they did if they had a proper systems view. I mean book to market and other idiocies. Not only is market information being incorporated immediately, but also the anticipated profits. What a charade.
Nassim Nicholas Taleb would be an example of how the finance world is waking up to the true nature of randomness - yet also how far people in that world still have to go.
Final word: you protest that traders in life are highly correlated. And indeed they try to be in following the herd (so as to beat the herd). But what we were discussing was the model rather than the reality. Which is a model based on a lack of long range correlations.
You state this yourself in saying the system has no memory and immediately incorporates its future. The long term is erased. Only the shortest possible term exists. And this is "efficient" in that it allows for flocking behaviour with volatility so extreme it models a drunkards walk.
It is "efficient" in the sense that it is exponential growth driving the same way e coli will fill an agar plate. Heaven forbid high finance would model the constraints to growth as well. Let's just create systems that we accelerate as fast as we can until they strike some wall.
  • #54
thanks for the try but I do not know what you are talking about. A Martingale does not have to be a random walk and certainly is not in various markets. The distinction of short and long term is irrelevant to the mechanics of the underlying process. I just don't get what you are saying. I'm not sure why you are hammering market participants. I guess they were all stupid. I was not a quant.
<h2>1. What is randomness?</h2><p>Randomness refers to the concept of unpredictability and lack of pattern or order in a sequence of events. It is often associated with probability and chance, and is a fundamental concept in mathematics, statistics, and science.</p><h2>2. How does randomness affect financial markets?</h2><p>The unpredictable nature of randomness can have significant implications in financial markets. Random events, such as changes in consumer behavior or unexpected economic shifts, can lead to fluctuations in stock prices and other financial instruments. This can impact investment decisions and overall market stability.</p><h2>3. Can we predict or control randomness in finance?</h2><p>While we can use statistical models and algorithms to analyze and make predictions about financial markets, it is impossible to fully predict or control randomness. This is because there are countless variables and factors that can influence market behavior, making it difficult to accurately predict outcomes.</p><h2>4. How do financial institutions manage the risk of randomness?</h2><p>Financial institutions use various risk management strategies, such as diversification, hedging, and portfolio optimization, to mitigate the impact of randomness on their investments. These strategies aim to reduce the overall risk exposure and protect against potential losses caused by random events.</p><h2>5. Is there a relationship between randomness and long-term financial success?</h2><p>While randomness can lead to short-term fluctuations in financial markets, it is not necessarily a determining factor in long-term financial success. Other factors, such as sound investment strategies and market knowledge, play a more significant role in achieving sustained financial success.</p>
  • Quantum Physics
  • Quantum Physics
  • Quantum Interpretations and Foundations
