Why is the Popup Menu Appearing Twice When I Add a Color?
  • Java
  • Thread starter BiGyElLoWhAt
In summary, the code is attempting to add a color using a try block and JOptionPane, but is experiencing issues due to an action listener being added twice. Once this issue is resolved, the code should work properly.
BiGyElLoWhAt
131
Code:
        else if(e.getSource() == add)
            try{
                int redInt = Integer.parseInt(red.getText());
                int greenInt = Integer.parseInt(green.getText());
                int blueInt = Integer.parseInt(blue.getText());
                String s = (String)JOptionPane.showInputDialog("Enter Your Color Name");
                colorPane.addColor(redInt, greenInt,blueInt, s);
            catch(Exception ex)
                System.out.println("You must enter a number in all fields!");
I call this with a button (add) and it all works fine, however, when I hit ok, it adds the color, but brings the menu popup back as if I had just hit the add button. If you hit ok the second time, though, it goes away. What am I missing? If you need any other code snippets let me know.
Technology news on Phys.org
Disregard. I added my action listener twice. Once when I instantiated the buttons and a second time when I added the buttons to the panel.
BiGyElLoWhAt said:
Code:
            try{
            catch(Exception ex)
The try block is expecting you to enter a string for the color name. Are you doing this? Hitting the OK button could be setting s to an empty string, which could be causing problems with the addColor() function.
Edit: Never mind, as the problem seems to be figured out.
Likes BiGyElLoWhAt
1. Why does the popup appear twice?
There are a few possible reasons for this. One possibility is that there is a coding error that is causing the popup to be triggered twice. Another possibility is that the popup is set to appear on multiple triggers, such as both a button click and a page load. Lastly, it could be a browser or device-specific issue.
2. How can I prevent the popup from appearing twice?
To prevent the popup from appearing twice, you will need to carefully review your code and ensure that there are no errors causing the double trigger. You can also try setting the popup to only appear on one trigger, such as a specific button click.
3. Can the user's browser or settings affect the popup appearing twice?
Yes, the user's browser or settings can potentially affect the popup appearing twice. For example, if the browser has certain extensions or settings that interfere with popups, it could cause the popup to appear multiple times. It is important to test the popup on different browsers and devices to ensure it works properly for all users.
4. Is there a specific type of popup that is more prone to appearing twice?
There is not necessarily a specific type of popup that is more prone to appearing twice. However, popups that are triggered by multiple events or have complex coding may be more likely to experience issues with appearing twice.
5. How can I troubleshoot the issue of the popup appearing twice?
If you are experiencing issues with the popup appearing twice, you can troubleshoot by reviewing your code for any errors, testing on different browsers and devices, and simplifying the trigger for the popup. You can also seek help from a web developer or utilize online resources for troubleshooting common popup issues.
