Integrating Compressible Flow Equations for V as a Function of x in MATLAB
The discussion revolves around simplifying the compressible flow equation to express V as a function of x for implementation in MATLAB. The user is struggling with integrating the equation due to the dependency on V(x), which complicates the integration process. They derived the equation from fundamental fluid dynamics principles but are unsure how to proceed without knowing the specific form of V(x). A suggestion is made to express the integral in terms of f'(x) and x, but the feasibility of integration depends on the exact nature of f(x). The user aims for an analytical solution rather than a numerical one, indicating a preference for a direct function representation in MATLAB.
yangshi
( V1.4 A.4 C1 - (1/V) ) dV = dA / A
C1 is a constant, V=f(x), A=.25*pi*(.0222 - x2)
I'm trying to simplify the equation into a form with no integrals or derivatives, so I can put it into MATLAB to spit out an expression for V as a function of x. Or is it possible to put all this into MATLAB (r2011a)? Sorry about the notation; I'm new to this.
Derived this expression from Euler's, energy, ideal gas, continuity, and calorically perfect equations for compressible, isentropic flow. If I integrate both sides, I have trouble integrating:
V1.4 A.4 dV
It seems I have to know V(x) in the first place to integrate with respect to V.
V1.4 A.4 dV
Using your definitions, we have
V^{1.4} A^{.4} dV = f(x)^{1.4} (a(b^2 - x^2))^{.4} d f(x),
where ##a = \pi/4, \: b = 0.22##. You can write ##df(x) = f'(x) \, dx##, so your integral has the form
\int f'(x) f(x)^{1.4} (a b^2 - a x^2)^{.4} \, dx
Whether or not this is "doable" depends on the form of the function ##f(x)##. You have not told us what is ##f(x)##.
I'm actually trying to figure out an expression for V=f(x). I know V=f(x) decreases when A increases, though I expect V=f(x) to be some ridiculous function. I'm trying to approach the problem analytically instead of numerically finding V, though it may be possible to input the whole function into MATLAB since everything's in terms of x. Thanks!
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
