Postulates of Special Relativity: Speed of Light in Inertial Frames
In summary: OK thanks I will read them.In summary, the speed of light in a transparent medium is not invariant and there is only one invariant speed, which is the speed of light in vacuum. The speed of light in a medium can be calculated using the velocity transformation law, which also applies to other objects with a different velocity. The fact that the speed of light and the invariant speed are the same may just be a coincidence and there is currently no fundamental reason for the photon to be exactly massless.
Q1111
TL;DR Summary
About the second postulate
Would the second postulate (The speed of light in free space has the same value c in all inertial reference frames.)be also true if it was in some medium instead of in free space? I know the value won't be c anymore but I want to know whether the speed of light in that medium would be the same in all inertial reference frames? Please tell how do we know.
No. The speed of light in a transparent medium is not invariant. There is only one invariant speed and that is the speed of light in vacuum.
Likes Q1111 and vanhees71
Q1111 said:
Summary:: About the second postulate
The velocity transformation law applies in all cases. If ##u## is the velocity of an object in one reference frame (e.g. the speed of light in a medium); and ##v## of relative velocity of the reference frame to another reference frame; then the velocity of the object in the second reference frame, ##u'## is given by:
$$u' = \frac{u + v}{ 1 + \frac{uv}{c^2}}$$ Some examples:
1) If ##u = c##, i.e. the speed of light in vacuum in one reference frame, then: $$u' = \frac{c + v}{ 1 + \frac{cv}{c^2}}= c\frac{1 + \frac v c}{1 + \frac v c} = c$$ And we find that the invariance of the speed of light is maintained by our velocity addition formula. Note that was independent of ##v## the relative velocity between the reference frames.
2) If ##u = 0.9c## and ##v = 0.9c##, then $$u' = \frac{1.8c}{ 1 + \frac{0.81c^2}{c^2}} = \frac{1.8c}{1.81} < c$$ and we see that the speed of the object is till less than ##c##. I.e. this formula never results in a speed greater than ##c##.
3) The second example applies to your case of light moving at less than ##c## in some medium - e.g. moving at ##0.9c## in a medium with a refractive index of ##1.1##. If that medium is moving at velocity ##v## in some reference frame, then the velocity transformation rule applies.
Likes Q1111, vanhees71 and Dale
Thank you.
Likes Dale
Thanks for explanation. I understood.
An invariant speed must also be the maximum speed. It seems that it's just a coincidence that light travels at this speed. Perhaps there's a deeper underlying explanation as to why they're the same. On the other hand, it may be that they are not the same. Note that if they are not the same then no modifications of relativity would need to be made. The speed ##c## would simply be called the invariant speed instead of the speed of light.
At the present status of the most fundamental theory describing matter and radiation (the Standard Model of elementary particle physics) there's indeed no fundamental reason that the photon must be exactly massless. An Abelian gauge boson can be massive without using the Higgs mechanism and without violating gauge symmetry (in contradistinction to non-Abelian gauge bosons which can only get massive using the Higgs mechanism without violating gauge symmetry and then making the entire model inconsistent). In this sense the photon mass has to be determined empirically as all of the masses of the elementary particles in the Standard model. The accepted upper limit is ##m_{\gamma}<10^{-18} \; \text{eV}##:
https://pdg.lbl.gov/2020/listings/rpp2020-list-photon.pdf
Likes Q1111 and PeroK
Thanks for mentioning this.
1. What is the speed of light in a vacuum according to the postulates of special relativity?
The postulates of special relativity state that the speed of light in a vacuum is constant and independent of the observer's frame of reference. This speed is approximately 299,792,458 meters per second.
2. How does the speed of light in a vacuum affect the perception of time and space?
According to the postulates of special relativity, the speed of light in a vacuum is the same for all observers, regardless of their relative motion. This leads to the concepts of time dilation and length contraction, where time and space are perceived differently by observers in different frames of reference.
3. Can anything travel faster than the speed of light?
No, according to the postulates of special relativity, the speed of light in a vacuum is the maximum speed at which anything can travel. This is because as an object approaches the speed of light, its mass and energy increase infinitely, making it impossible to reach or exceed the speed of light.
4. How do the postulates of special relativity explain the phenomenon of simultaneity?
The postulates of special relativity state that simultaneity is relative and depends on the observer's frame of reference. This means that events that appear simultaneous to one observer may not appear simultaneous to another observer in a different frame of reference.
5. What are the implications of the postulates of special relativity for our understanding of the universe?
The postulates of special relativity have revolutionized our understanding of the universe by showing that time and space are not absolute and can be perceived differently by observers in different frames of reference. This has led to the development of theories such as the theory of relativity and has greatly influenced modern physics and cosmology.
