Potential due to a plate
  1. Jun 25, 2007 #1
    i was going through the proof of the classical image problem in which u have agrounded conductor and you have a charge q above it and u r asked to find potenntial at all points above the conductor the proof uses the fact that the potential due to the sheet at "all" infinities is 0.how does one justify this
  3. Jun 25, 2007 #2
    olgranpappy
    If the potential goes to zero at infinity as approached in one direction then it goes to zero in all directions because outside the region containing the charge (far from the plate and the pt charge) I am just solving the Laplace equation. Thus, the angular dependence is given by Legendre polynomials and the radial dependence is at most 1/r. Since the Legendre polynomials never blow up the potential falls off at least as fast as 1/r regardless of the direction.
  4. Jun 26, 2007 #3
    what about a point infinitely seperated from the point charge but just above the plate
  5. Jun 26, 2007 #4
    it is also zero!
  6. Jun 27, 2007 #5
    well how is that proved?
  7. Jun 28, 2007 #6
    Because of the symmetry, the field line above the plate will be upwards. Assume you move the electron along the field lines. The electron will always accelerated along the field lines, i.e., the potential will decrease. The key issue here is the word "infinitely", it means that you can move an electron along the field lines infinitely untill the potential decrease to zero!!
  8. Jun 28, 2007 #7
    yes far above the plates that is true but what i asked before and now is a point far from the point cahrge but just close to the plate
  9. Jun 28, 2007 #8
    and one more thing adding to the problem is the situation is highly unsymmetrical
  10. Jun 28, 2007 #9
    hi, Pardesi:
    A point far from the point charge means that the electric potential caused by the point charge can be neglected; close to the plate means that its potential is near the potential of the plate. so it is also zero
    The key point is that the potential caused by the point charge is inversely proportional to the distance from the charge. So basically , at the infinitely far away from the partical charge, the potential due to the particle charge is zero.
  11. Jun 28, 2007 #10
    CompuChip
    It doesn't matter. The potential of a point charge is [tex]\propto 1/r[/tex]; so it drops to zero at infinity and therefore so does the (potential of the) induced charge in the plate.
  12. Jun 28, 2007 #11
    so if i am not wrong the fundamental point is inverse propotionality of v with r and the continuity of v
  13. Jun 28, 2007 #12
    Ja, you got the point!
  14. Jun 28, 2007 #13
    thank u all
    :rolleyes:
