Potential energy graphing
  1. Feb 7, 2017 #1
    The potential energy V(R) of a two particle system exhibiting oscillatory behavior near a local minimum at the equilibrium separation Ro. V(R)= -(A/R)+(B/R^2) , where R is the interparticle separation.
    A) Sketch V(R), what happens to V(R) as R→0
    B) At what value of R is there a minima in the potential?
    C) For very small oscillations about this equilibrium point, Ro, write the force on the particle F=-k(R-Ro), define k.
    2. Relevant equations
    3. The attempt at a solution
    I must apologize in advance because I feel that I'm about to ask a stupid question. But how can I plot this function if I don't know what the values of A and B are?
  3. Feb 7, 2017 #2
    TSny
    2017 Award
    It's a good question.
    What if you plot ##V## in units of ##A^2/B## and ##R## in units of ##B/A##?
    [Edited to correct a mistake.]
  4. Feb 7, 2017 #3
    PeroK
    I would have just taken ##A = B = 1## for the purpose of a sketch.
  5. Feb 7, 2017 #4
    Sorry, I'm not sure how I would plot the function in those terms such as A^2/B and B/A. Do you think I can fix the values like PeroK suggested? My only concern is that the function slightly changes based on what A and B are. But I see that the function runs off to infinity as R approaches 0.
  6. Feb 7, 2017 #5
    TSny
    2017 Award
    Yes, you can go with PeroK's suggestion. The graph will be the same as I was suggesting.
    Note that ##A^2/B## has the dimension of energy and ##B/A## has the dimension of length.
    So, you can introduce dimensionless quantities ##\tilde{V} = \frac{V}{A^2/B}## and ##\tilde{R} = \frac{R}{B/A}##.
    If you write the equation in terms of these dimensionless quantities ##\tilde{V}## and ##\tilde{R}##, you should find that ##A## and ##B## disappear.
    Graphing ##\tilde{V}## versus ##\tilde{R}## will give the same graph as graphing ##V## versus ##R## with ##A= B = 1##.
  7. Feb 7, 2017 #6
    Thanks for your explanation. I wasn't used to this method so I couldn't see the relationship before. For part B where it asks to find the minimum, taking A=B=1, I found an equilibrium point at R=1. Would it be correct for me to use the first derivative test?
  8. Feb 7, 2017 #7
    TSny
    2017 Award
    For A = B = 1, I don't think the equilibrium is at R = 1. But, I'm pretty sure that you are meant to express the equilibrium value of R in terms of A and B.
    Yes, use differentiation to find the minimum.
  9. Feb 7, 2017 #8
    So then the equilibrium value of R is at R=(B/A)? I found this by leaving A and B as variables and setting V(R)=0.
  10. Feb 7, 2017 #9
    TSny
    2017 Award
    The equilibrium condition is not V(R) = 0. Equilibrium is where the force is zero.
  11. Feb 7, 2017 #10
    Since V(R) is given as the potential energy function in the problem, I can find my force function by using F(x)=-du/dx. Is that the right idea?
  12. Feb 7, 2017 #11
    TSny
    2017 Award
    Yes. Good.
Have something to add?
Draft saved Draft deleted
Similar Discussions: Potential energy graphing
Loading...
