Why is potential energy considered negative in an inversed pendulum system?
In summary, the conversation discusses an inversed pendulum and the chosen coordinate system. The potential energy is represented by PE=mgz, with z being negative at the upwards position. However, the textbook takes the absolute value of h, causing confusion about the placement of the zero for h. The issue was resolved by fixing the location of the zero at the point of rest for the pendulum, which also addressed the problem of negative angles and work.
Andrax
117
we have an inversed pendulum(ignore the car)
and we choose the coordinate system to be upwards
the potential energy PE=mgz (z will be hegative since( O,k) is upwards right?) z is always under O.
but in the textbook they basically take the absolute value of h i don't understand why?
Where is the textbook putting the zero of h?
at the point of rest of the pendulum (same as O)
fixed the problem (h ad to do with angle being negatgive which means the work of p is negative)
sorry my explication of the question was off , close this thread
I would clarify that potential energy is a relative quantity, meaning it can only be measured in comparison to a reference point. In the case of an inverted pendulum, the reference point is typically chosen to be the lowest point of the pendulum, where the potential energy is considered to be zero. This means that as the pendulum moves upwards, the potential energy increases and becomes positive. However, if we choose a different reference point, for example the highest point of the pendulum, then the potential energy would be negative at the lowest point and decrease as the pendulum moves upwards.
The reason why the textbook may take the absolute value of the height is to simplify the calculations and avoid dealing with negative values. It is important to note that the magnitude of the potential energy is what matters in determining the behavior of the system, rather than its sign. So whether we use the absolute value or not, the physical principles and equations would still remain the same.
What is potential energy and how is it related to negative values?
Potential energy is the energy that an object has due to its position or configuration. It is related to negative values because in physics, potential energy is often measured relative to a zero point, and the negative sign indicates that the object is at a lower energy state than the zero point.
Why is potential energy sometimes negative?
Potential energy can be negative when the zero point is chosen at a higher energy state than the object's current position. This can happen in situations where the object is at a lower height, or in a weaker gravitational field, than the chosen zero point.
Can negative potential energy still be used to do work?
Yes, negative potential energy can still be used to do work. This is because potential energy is a relative concept and what matters is the difference in potential energy between two points. So even if an object's potential energy is negative, it can still be converted into other forms of energy and do work.
What are some examples of negative potential energy?
One example of negative potential energy is a ball sitting at the bottom of a hill. If the top of the hill is chosen as the zero point, the ball's potential energy would be negative at its current position. Another example is an electron in an atom, where the zero point is often chosen to be at infinity and the electron's potential energy is negative due to its attraction to the nucleus.
How does negative potential energy affect an object's motion?
Negative potential energy does not directly affect an object's motion. It is the change in potential energy that causes a change in an object's motion. However, negative potential energy can indicate that the object is at a stable or equilibrium position, where it will not experience any net force and therefore will not move.
10K
10K
  • Mechanics
