Re: How do I find the potential for this unusual pendulum?
In summary, a unique pendulum is created by attaching a string to a horizontal cylinder and hanging a mass from the end. The potential energy can be found by calculating the change in potential energy, defined as the negative integral of the force acting on the mass. The length of the pendulum changes as it swings, but can be determined by finding the point of tangency and adding the arc length to the original length. The potential energy is then given by the formula $mg(l_{0}+y)$, where $y$ is the height from a chosen zero point.
Dustinsfl
2,281
An unusual pendulum is made by fixing a string to a horizontal cylinder of radius $R$, wrapping the string several times around the cylinder, and then tying a mass $m$ to the loose end.
In equilibrium the mass hangs a distance $l_0$ vertically below the edge of the cylinder.
Find the potential energy if the pendulum has swung to an angle $\phi$ from the vertical.
The definition for potential energy is
U(\mathbf{r}) = -W(\mathbf{r}_0\to\mathbf{r}) = -\int_{\mathbf{r}_0}^{\mathbf{r}}\mathbf{F}(\mathbf{r}')\cdot d\mathbf{r}'
Mathematics news on Phys.org
Re: potential energy
Actually, $W=-\Delta U$. Absolute potential energy has no physical meaning, only a change in potential energy. The only forces on the mass are gravity and the tension in the string. The trick with this problem is that when the mass swings, the cylinder is either taking up more string, or releasing string. So the length of the pendulum is changing.
Let us define $y$ positive up, $x$ positive to the right, and $\phi$ positive in the counter-clockwise direction from the $+x$ axis, as usual. Let us assume that the cylinder's center is at the origin, and that the string is hanging in equilibrium from a point of tangency that is on the positive $x$ axis.
Several key concepts here: the potential energy due to the gravitational force is given by $mgh$, where $h$ is the height above some zero point for the energy. When the mass swings, the string is always tangent to the cylinder, and hence the angle $\phi$ that the pendulum has swung is also the angle $\phi$ which the string has either wrapped more around the cylinder or less. Therefore, the arc length of additional string taken up is given by $s=\phi R$. So the length of the pendulum is always $l_{0}+s$. If we can find the point of tangency as a function of $\phi$, and then go $l_{0}+s$ along the string, we'd arrive at the mass.
Then the vector to the point of tangency $P_{t}$ we can write as
$$\mathbf{P}_{t}=R \, \langle \cos( \phi), \sin( \phi) \rangle.$$
From the point of tangency, the mass is then located a distance $l_{0}+ \phi R$ away, at an angle of $\phi$ from the vertical. Hence, the vector $\mathbf{r}$ from the point of tangency to the mass is given by
$$\mathbf{r}=(l_{0}+ \phi R) \, \langle \sin( \phi), -\cos( \phi)\rangle.$$
The minus sign on the $y$ component reflects the fact that we've defined $y$ positive down. Hence, for any angle $\phi$, the $y$-coordinate of the mass is given by the sum of the $y$ components of these two vectors, or
$$y=R \sin(\phi)-(l_{0}+ \phi R) \cos( \phi).$$
We can just define our zero point to be when $\phi=0$, in which case $y=-l_{0}$. Therefore, the height $h$ in the formula $U=mgh$ is given by $U=mg(l_{0}+y)$, since
$l_{0}>0$ and $y<0$. Therefore, the potential energy is
$$U=mg\left[l_{0}+R \sin( \phi)-(l_{0}+ \phi R) \cos( \phi)\right].$$
1. What is potential energy?
Potential energy is the energy that an object has due to its position or state. It is the stored energy that can be converted into other forms, such as kinetic energy, to do work.
2. How is potential energy different from kinetic energy?
Kinetic energy is the energy an object has due to its motion, while potential energy is the energy an object has due to its position or state. Kinetic energy is the energy of movement, while potential energy is the energy of position.
3. What are the types of potential energy?
There are several types of potential energy, including gravitational potential energy, elastic potential energy, chemical potential energy, and nuclear potential energy. Gravitational potential energy is the energy an object has due to its position in a gravitational field, while elastic potential energy is the energy stored in a stretched or compressed object. Chemical potential energy is the energy stored in the bonds between atoms, and nuclear potential energy is the energy stored in the nucleus of an atom.
4. How is potential energy calculated?
The formula for calculating potential energy depends on the type of potential energy. For gravitational potential energy, the formula is PE = mgh, where m is the mass of the object, g is the acceleration due to gravity, and h is the height of the object. For elastic potential energy, the formula is PE = 1/2kx^2, where k is the spring constant and x is the displacement from the equilibrium position. For chemical and nuclear potential energy, the calculations are more complex and depend on the specific system.
5. How can potential energy be changed into other forms of energy?
Potential energy can be converted into other forms of energy, such as kinetic energy, thermal energy, or electrical energy, through various processes. For example, when an object falls, its gravitational potential energy is converted into kinetic energy. When a stretched rubber band is released, its elastic potential energy is converted into kinetic energy. Chemical potential energy can be converted into thermal energy through combustion, and nuclear potential energy can be converted into electrical energy through nuclear reactions.
  • Classical Physics
  • Classical Physics
  • Math Proof Training and Practice
