Potential in capacitance network
In summary, a capacitance matrix represents the charge coupling within a group of conductors and the net charge on each object can be calculated using the given equations. However, if all capacitances are known and V1-V2 is known, it is not possible to calculate V3 or Q3 without additional input information. In the equivalent circuit of the capacitor network, the voltage of conductor 3 to the reference ground can be calculated.
hectoryx
A capacitance matrix represents the charge coupling within a group of conductors — that is, the relationship between charges and voltages for the conductors. Given the three conductors shown in the following link, with the outside boundary taken as a reference,
http://i1021.photobucket.com/albums/af335/hectoryx/capacitancenetwork.jpg
the net charge on each object will be:
[tex]$\begin{array}{l}
{Q_1} = {C_{10}}{V_1} + {C_{12}}({V_1} - {V_2}) + {C_{13}}({V_1} - {V_3}) \\
{Q_2} = {C_{20}}{V_2} + {C_{12}}({V_2} - {V_1}) + {C_{23}}({V_2} - {V_3}) \\
{Q_3} = {C_{30}}{V_3} + {C_{13}}({V_3} - {V_1}) + {C_{23}}({V_3} - {V_2}) \\
\end{array}$
[/tex]
The problem is, if all of the capacitances are already known, and [tex] {V_1} - {V_2} = U [/tex] is also known, but [tex]{V_1}[/tex] and [tex]{V_2}[/tex] is not known.
then how to calculate [tex]{V_3} [/tex] or [tex]{Q_3}[/tex]?
Thanks in advance.
Regards
Hector
I don't believe that it is possible. You have six unknowns, but only four equations. Do you know any other values besides just V1-V2? Two more independent values should do it.
Thanks for your reply.
However, in the equivalent circuit of the capacitor network, the voltage of conductor 3 to the reference ground can be caculated...so...
hectoryx said:
... in the equivalent circuit of the capacitor network, the voltage of conductor 3 to the reference ground can be caculated ...
Are you suggesting that this is possible if you only know V1-V2? I don't believe so. If you simply mean that, yes, there is this additional input information, then the solution is trivial: V3=V3, right? I must not be understanding your problem.
1. What is potential in a capacitance network?
Potential, also known as voltage, is the electric potential energy per unit charge in a capacitance network. It is the driving force that causes charges to move from one capacitor plate to another.
2. How is potential calculated in a capacitance network?
The potential in a capacitance network can be calculated using the formula V = Q/C, where V is the potential, Q is the charge stored in the capacitor, and C is the capacitance of the network.
3. What is the unit of potential in a capacitance network?
The unit of potential in a capacitance network is volts (V). This unit represents the amount of potential energy per unit charge.
4. How does the potential in a capacitance network affect the flow of current?
The potential in a capacitance network is directly related to the flow of current. A higher potential difference between two points in the network will result in a greater flow of current between those points.
5. Can potential in a capacitance network be negative?
Yes, potential in a capacitance network can be negative. This means that the potential energy is decreasing as the charges move from one plate to another. It is common to see negative potentials in circuits with alternating current (AC).
