Potential of Infinite Sheets of Charge and Conducting Slab
  1. Jan 26, 2017 #1
    An infinite sheet of charge is located in the y-z plane at x = 0 and has uniform charge denisity σ1 = 0.39 μC/m2. Another infinite sheet of charge with uniform charge density σ2 = -0.15 μC/m2 is located at x = c = 30 cm.. An uncharged infinite conducting slab is placed halfway in between these sheets ( i.e., between x = 13 cm and x = 17 cm). What is σa, the charge density on the surface of the conducting slab at x = 13 cm?
    2. Relevant equations
    3. The attempt at a solution
    I know the electric field in the slab is zero, but I do not know how to find the charge density on the surface of the slab in this instance. Thanks for the help in advance!
  3. Jan 26, 2017 #2
    BvU
    2017 Award
    Would it matter if the conducting slab was 2000 cm thick instead of 2 cm (with of course the same distance between b and c) ?
Have something to add?
Draft saved Draft deleted
Similar Discussions: Potential of Infinite Sheets of Charge and Conducting Slab
Loading...
