Potential well solutions question
In summary: Thank you. In summary, the parameters d and k in the interior solution of a finite well have significant roles in determining the shape and starting point of the wave function. The amplitude of the wave is related to the length of the well, while the value of k is influenced by the energy of the particle and the potential energy of the well. The equation ka = n\pi - 2Sin^{-1}(\frac{k\hbar}{\sqrt{2mV_{o}}}) helps determine the values of k and d that satisfy the continuity requirements at the boundaries of the well.
physicsjock
89
Hey,
I've been trying to work out how, for a finite well of high Vo and width L, the interior solution has the form L Sin(kx + d),
I see that if d=0 then the solution resembles an infinite well, so that implies d depends inversely on the wells potential. But I can't work out what d comes from, and why the constant at the front is the length of the well (why is the amplitude of the wave the length of the well)
d is just the phase of the wave, so does it represent an adjustment to assure all the continuity requirements are satisfied?
Ive also been trying to work out what the k is, when I go through the process of finding the wave function inside I end up with (s/k)Asinkx + Acoskx after applying the boundary conditions.
where k2=2mE/[itex]\hbar^{2}[/itex]
and s2=2m(Vo-E)/[itex]\hbar^{2}[/itex]
i've been trying to work this out because I've also read that the below equation should also satisfy the internal solutions
ka = n[itex]\pi - 2Sin^{-1}(\frac{k\hbar}{\sqrt{2mV_{o}}})[/itex]
this makes it seem like d resembles the inverse sin term, which makes sense because if Vo ->infinity you would get the solution to an infinite potential well
Anyone have any ideas?
Hello,
Thank you for your interest in this topic. It seems like you have a good understanding of the basics of the problem. Let me try to explain the significance of the parameters d and k in the interior solution of a finite well.
First, let's consider the general form of the interior solution for a finite well:
Ψ(x) = A sin(kx + d)
Here, A represents the amplitude of the wave, which in this case, is related to the length of the well. This is because the amplitude of the wave is directly proportional to the probability of finding the particle in a particular region. In other words, the larger the amplitude, the higher the chance of finding the particle in that region. Since the length of the well represents the region where the particle is confined, it makes sense that the amplitude is related to it.
Now, let's look at the parameters k and d. As you mentioned, k is related to the energy of the particle through the equation k2=2mE/\hbar^{2}. This means that the value of k is determined by the energy of the particle, which in turn, is influenced by the potential energy of the well. So, different values of potential energy will result in different values of k, which will affect the shape of the wave function.
The parameter d, on the other hand, is related to the phase of the wave. It represents the starting point of the wave function, which is important in determining the continuity requirements of the wave. As you mentioned, if d=0, the solution resembles an infinite well. This is because in an infinite well, the wave function starts at 0 and repeats itself indefinitely. In a finite well, however, the wave function needs to be adjusted to satisfy the continuity requirements at the boundaries of the well. This is where the value of d becomes important.
Now, let's consider the equation ka = n\pi - 2Sin^{-1}(\frac{k\hbar}{\sqrt{2mV_{o}}}). This equation is derived from the boundary conditions of the well and it helps us determine the values of k and d for a specific energy level. This equation is valid for both the internal and external solutions, and it helps us determine the values of k and d that will satisfy the continuity requirements at the boundaries.
I hope this explanation helps clarify the significance of d and k in the interior solution of a finite well. Let me know
FAQ: Potential well solutions question
What is a potential well solution?
A potential well solution is a mathematical model used to describe the behavior of particles or systems in a confined space, where the potential energy is lower than the energy of the particles. This creates a "well" or dip in the potential energy curve, trapping the particles in the well and preventing them from escaping.
How are potential well solutions used in science?
Potential well solutions are used in a variety of scientific fields, including physics, chemistry, and engineering. They are particularly useful in understanding the behavior of particles in quantum mechanics, as well as in modeling the properties of atoms and molecules.
What are some real-world applications of potential well solutions?
Potential well solutions have many practical applications, including in the design of electronic devices such as transistors, in the study of chemical kinetics, and in the development of optical traps for manipulating small particles. They are also used in the study of quantum computing and in the analysis of atomic and molecular spectra.
What types of potential well solutions are there?
There are several types of potential well solutions, including square well, harmonic oscillator, and Coulomb potential well solutions. Each type has its own unique shape and mathematical properties, but all of them involve a dip in the potential energy curve that traps particles within the well.
How do potential well solutions relate to quantum mechanics?
Potential well solutions are an important concept in quantum mechanics, as they help to explain the behavior of particles on a microscopic scale. The confinement of particles in a potential well is analogous to the quantized energy levels of particles in an atom, and potential well solutions are often used to model the behavior of electrons in atomic orbitals.
