How Does Antenna Gain Impact RF Energy Distribution?
In summary, an antenna with a higher gain concentrates the available RF energy into a narrower beam, which can then be used to produce a power higher than the original at a receiver.
beckett
Hi,
I'm having difficulty understanding how the gain of an antenna works. I appreciate that the gain effectively concentrates the available RF energy into a narrower beam but i can't fathom how this seems to mean that if i have a transmitter transmitting at say 100dBm that i can use antenna gain to produce a power higher than this at a receiver. How is this possible to seemingly 'create' power?
If i supply an isotropic antenna with 40W of power then this theoretically will be dissipated equally in all direction so at any point away fom this i will receive a fraction of this. If i conentrate the energy by beam forming then surely the most i can expect to get is no more than the original 40W.
Also, when we say that the power at a certain point from the transmitter is XdBm what does this mean? i.e. surely it depends on the size of the receiver at that point so you can't make a general statement that at that point the power is XdBm?
Thanks in advance
Beckett
I don't know what you mean exactly, when I want to boost gain on my antenna, I need an operational amplifier circuit. The ability to boost the power comes from a 12V or 9V supply.
This formula gives the fraction of transmitted power when a EM wave is normally incident on a receiving medium.
[tex]T=1 - (\frac {\eta_2 - \eta_1} {\eta_2 + \eta_1})^2[/tex]
where [tex]\eta[/tex] is impedance of medium 1 or 2.
So the power transmitted will always be less, unless you have an effective impedance set up relevantly.
Concentrating Electric flux...well you will get more power per unit area, but the same power overall.
I guess the thing that confuses me is the following equation:
If if have a system wherein i transmit a power of 4dBm to an antenna, there is a loss of 6db in the transmission line and a gain of 18dBi then the following applies:
EIRP = Pout - Ct + Gt = 16 dBm
This to me suggests that an initial supply of 4dBm somehow magically becomes 16dBm.
Think of it this way. You have an omni directional antenna transmitting a signal. You place a receiving antenna at a short distance and note the received signals strength. Now you replace the transmitting antenna with antenna that has a gain of 10 db. The signal strength in the receiver now is 10 db higher than the previously noted reading. You sacraficed some signal in one direction and added signal in another. Now if you positioned the transmitting antenna wrong you may end up with the receiving antenna showing a lower reading than previously. You can do the same with a receiving antenna.
Hi Beckett,
I hope this analogy helps: Let's assume we can see the radiated RF power from the omnidirectional antenna as patterns of light--sort of like a flourescent light bulb. At a certain distance we can still see the light source but not too strong. Let's say without changing our location, there's a way to increase the intensity of the light source by using mirrors and lenses. If we add mirrors and/or lenses at the light source and situate them in away it increases the visibility or intensity (i.e. gain) at a certain direction (hopefully, to us!), the light source will appear brighter--and, if done correctly, much brighter to us!
(Of course, that is if our "receiver" eyes can see correctly)
Another simpler way of thinking about antennas and their patterns are similar to the type of light sources that are available, such as spot lights, flood lights, etc.
Hope this helps you visualize what's going on. :)
Folks, thanks for your help, i think I've got it now, these forums are so useful.
Its all about superposition of waves...if you take a single simple antenna element it will have a uniform dispersal. Multiple elements will add or subtract to the waves from each other creating areas where the signal is stronger or weaker. The total power is still the same but there are areas where it is multiplied. Reflective surfaces can also cause the same effects.
1. What is the relationship between power and gain in antennae?
The power and gain of an antenna are closely related, as they both determine the effectiveness of the antenna in transmitting and receiving signals. Power is the amount of energy that an antenna can transmit, while gain is a measure of the antenna's ability to focus that power in a specific direction. A higher gain antenna will have a stronger signal and be able to transmit or receive over longer distances.
2. How does the gain of an antenna affect its performance?
The gain of an antenna directly impacts its performance by determining its sensitivity and range. A higher gain antenna will have a stronger signal and be able to transmit or receive over longer distances. It also allows for better reception of weak signals and reduces interference from other sources.
3. What factors affect the gain of an antenna?
The gain of an antenna is affected by several factors, including its size, shape, and design. Generally, larger antennas have higher gain due to their ability to focus more power in a specific direction. The materials used to construct the antenna can also impact its gain, as well as the environment in which it is used.
4. How is the gain of an antenna measured?
The gain of an antenna is typically measured in decibels (dB). This measurement compares the signal strength of the antenna to that of a reference antenna, which is usually an isotropic radiator. The resulting measurement is known as the antenna's gain in dBi (decibels relative to isotropic).
5. Can the power and gain of an antenna be adjusted?
Yes, the power and gain of an antenna can be adjusted to some extent. For example, by changing the design or materials of the antenna, the gain can be increased. The power can also be adjusted by changing the amount of input energy or by using amplifiers. However, there are limits to how much the power and gain can be adjusted without affecting other aspects of the antenna's performance.
  • Classical Physics
  • Electrical Engineering
  • Astronomy and Astrophysics
