Power Rating of 570 W Heaters in Series: 1140 W
BuffettIn summary, when two 570 W heaters are connected in series to a voltage of 120V, the power consumed by both heaters is 570 W each, for a total of 1140 W. This is because the voltage remains the same while the resistance is doubled, resulting in half the power being consumed by each heater.
GreenDinos
Q20-9. The power rating of a 570 W heater specifies the power consumed when the heater is connected to an ac voltage of 120V. What is the power consumed by two of these heaters connected in series, connected to the same voltage?
570 W
285 W
1140 W
2280 W
142.5 W
ok, my original thinking was that the 120V will supply 570 W of power and that two in a series would still have a total power of 570W (285W each)...but that was wrong...so is it double the power (1140W)- is the power consumed still 570W for each heater- and so 1140 is the total?
thanks
Power is voltage times current. Ohm's law says voltage is current times resistance.
[tex]P = V \cdot I = \frac{V^2}{R}[/tex]
Solving for resistance:
[tex]R = \frac{V^2}{P}[/tex]
Replacing R with 2R:
[tex]P_{\textrm{both}} = \frac{V^2 \cdot P}{2 V^2} = \frac{P}{2}[/tex]
- Warren
for your response!
In this scenario, when two 570 W heaters are connected in series, the total power consumed would be 1140 W. This is because when heaters are connected in series, the voltage remains the same, but the current is divided between the two heaters. So each heater would still consume 570 W, but together they would consume a total of 1140 W. This is because power is calculated by multiplying voltage by current, and in this case, the voltage remains constant at 120V for both heaters. Therefore, the power consumed by two 570 W heaters connected in series would be 1140 W.
1. What is the purpose of using multiple 570 W heaters in series?
The purpose of using multiple heaters in series is to increase the total power output. By connecting the heaters in series, the voltage across each heater remains the same, but the current passing through them adds up, resulting in a higher power rating.
2. How does the power rating of 570 W heaters change when connected in series?
The power rating of the heaters does not change when connected in series. Each heater still has a power rating of 570 W. However, the total power output is increased due to the increase in current passing through the heaters.
3. Can the power rating of 570 W heaters in series be less than 1140 W?
No, the power rating of heaters connected in series cannot be less than 1140 W. This is because the total power output is always equal to the sum of individual power ratings. In this case, the total power output will always be 1140 W.
4. What happens if one of the heaters in the series fails?
If one of the heaters in the series fails, the total power output will decrease. This is because the current passing through the remaining heaters will also decrease, resulting in a lower power rating. It is important to ensure all heaters are functioning properly to maintain the desired power output.
5. Is it possible to connect heaters with different power ratings in series?
Yes, it is possible to connect heaters with different power ratings in series. However, it is important to note that the total power output will be limited by the heater with the lowest power rating. This means that if one of the heaters has a power rating lower than 570 W, the total power output will be lower than 1140 W.
  • Electrical Engineering
