Power cross-spectral density
  1. Oct 26, 2012 #1
    Hi all,
    I am curently working with frequency response functions on the basis of 1 input data sample and 1 output data sample. As I would like to plot the coherence function, I need to compute the cross-spectral densities. Since I am new to this field, I would like to ask some of you experts whether it is correct to compute a power cross-spectral density (pcsd) as
    2. Relevant equations
    pcsd_xy = psd_xx.*conj(psd_yy)
    where psd = power spectral density.
    3. The attempt at a solution
    Is this a correct approach to obtain the cross-spectral density?
    Kind regards,
    Martin.
  3. Oct 26, 2012 #2
    marcusl
    No, that's not going to do it. Look at the definition of the cross-power PSD from the Wiener-Khinchin theorem
    [tex]S_{xy}(\omega)=\int_{-\infty}^{\infty}{R_{xy}(\tau)e^{-i\omega \tau} d\tau},[/tex]where R is the cross-correlation function
    [tex]R_{xy}(\tau)=\int_{-\infty}^{\infty}{x(t) y^*(t+\tau)dt}.[/tex]You can see that you can't get the above from what you wrote (note that your PSD S_xx is found by setting x=y).
  4. Oct 27, 2012 #3
    Thanks for the answer. Then I have probably made an error on an earlier state since I obtain compliance between the frequency response function when I use
    S_xx(w)=|H(w)|^2 S_ff(w)
    and
    S_xx(w)=H(jw)S_xf(w).
    I have posted a small MATLAB script in which I compute these quantities. I know it is a lot to ask for but can you spot something wrong with my computation of the PSDs?
    % Time increment %
    dt=t(2)-t(1);
    % Number of samples %
    N=2^nextpow2(length(t));
    % Frequency band %
    f=1/dt/N*(0:(N-2)/2);
    % --- Fast Fourier transformation --- %
    % Input data %
    Ft_in=fft(wdata_in,N);
    % Output data %
    xt_out=fft(wdata_out,N);
    % --- Power spectral densities --- %
    % Power spectral density of input data %
    PSD_in=Ft_in.*conj(Ft_in)/N;
    % Power spectral density of output data %
    PSD_out=xt_out.*conj(xt_out)/N;
    % Power cross-spectral densities of input and output data %
    PCSD_in_out=Ft_in.*conj(xt_out)/N;
    PCSD_out_in=xt_out.*conj(Ft_in)/N;
    % Frequency response function %
    H=PSD_out(1:N/2)./PCSD_out_in(1:N/2);
    Your answer would be highly appreciated.
    Thanks in advance and kind regards,
    //Martin.
  5. Oct 27, 2012 #4
    marcusl
    Your input and output PSD's are correct, your cross power calculation is not. You are getting a pleasing result because cross-power would be the wrong thing to use, were you to calculate it correctly. The transfer function is [tex]H(\omega)=\frac{Y(\omega)}{X(\omega)},[/tex] where Y and X are the output and input spectra of your system. Look at your code--you in fact calculate H*, albeit through a very convoluted process.
  6. Oct 28, 2012 #5
    Again, thank you very much for the answer.
    The reason why I want to use the cross-power is that I want informations about the phase angle as well as the magnitude.
    So what you are saying is that I through
    actually get the complex conjugate of H?
  7. Oct 28, 2012 #6
    marcusl
    Take a look at your own code:
    What does it look like to you?
Similar Discussions: Power cross-spectral density
  1. The Spectral Theorem (Replies: 2)
  2. Spectral Decomposition (Replies: 18)
Loading...
