Power = current * voltage sometimes?
  • Thread starter Pengwuino
Pengwuino
I thought power is current * voltage in all cases... but someone told me its only true "sometimes". Now the people on the forum that I heard this from are usually wrong all the time so i wanted to check it out.
Answers and Replies
Renge Ishyo
282
I have heard the same thing, in certain circumstances (most notably with AC circuits) P = V(I) supposedly gives the wrong answer. As for why, that was never explained to me clearly and I was never given a direct example to see. This was mentioned to me as a side note when introducing the formula P = I^2(R) which apparently always gives the correct answer.
Pengwuino
But arent they all derivations of eachother? I know theres something called RMS but i dont thinkt hats what there talking about.
Renge Ishyo
282
I have always had a problem with this too. If you substitute R=V/I into the equation that "always works" you get:
P = I^2(V/I)
Which simplifies to...P=I(V)!
There are only two possibilities I can think of: one, that I was told the wrong thing and that you can use V(I) or two, that there is some sort of problem with measuring "voltage" in ac circuits and then applying it to this equation (maybe because the sign for Voltage changes direction in AC?). If you determine the resistance on say, a resistor connected to a DC circuit, and then remove that resistor and place it on an AC circuit I can see how using P=I^2(R) would be much easier to measure (you wouldn't have to deal with the problem of measuring voltage in this instance), but at the same time I am not sure what they mean when they say using V(I) will give you the wrong answer.
Tide
3,089
I think the problem you are asking about has to do with the fact that Ohm's law is an approximation that can fail when the fields are too strong. For example, in an isotropic medium, the electrical current density is usually written in terms of the electric field as [itex]\vec j = \sigma \vec E[/itex] (for an isotropic medium) where [itex]\sigma[/itex] is the electrical conductivity. Notice that it is a linear relationship and is valid provided the electric field isn't too intense.
Generally, however, the conductivity can depend on the strength of the electric field such as in a conductor or plasma. It is a property of Coulomb collisions between electrons and ions (the source of resistivity!) that the faster electrons move the less effective the scattering becomes. The oscillatory velocity of electrons produced, for example, by an electromagnetic wave depends on the amplitude of that wave and, therefore, the conductivity also depends on the amplitude of the applied electric field.
Similar effects occur during dielectric breakdown that occurs during an electrical discharge.
Integral
Staff Emeritus
63
P=IE is directly related to Ohms law, and therefore only holds for purely resistive DC circiuts. In AC circiuts you must consider the reactive impedance. The impedance is dependent upon the frequency as well as the circiut resistance, inductance and capacatance. P=IE will also have a reactive component in AC circiuts, making it different from that of a pure resistive DC circiut.
The instant power in an electric circuit is [tex]p(t) = v(t).i(t)[/tex].
This is allways valid. What happens with reactive circuits and sinusoidal voltages and currents is that the peak value of the power is different of the product of the peak values of voltage and current.
[tex]P_{max} = V_{max} . I_{max} . cos(\phi)[/tex]
Where [tex]\phi[/tex] is the phase angle between voltage and current.
Clausius2
It depends of what kind of power do you want to measure:
First, check: https://www.physicsforums.com/showthread.php?t=86053
Secondly, it depends of what kind of system are you analyzing. For instance, P isn't VI in tri-phase systems or in non-completely resistive AC systems.
Crosson
1,259
Power is the rate of doing work, energy per time.
P = IV
[tex]\frac{energy}{time} = \frac{charge}{time} \frac{energy}{charge}[/tex]
This is always true, anything else in an engineer's confusion.
Doc Al
Mentor
45,425
1,876
The instantaneous values of V & I always satisfy P = IV. But if I and V represent the rms values in an AC circuit, then to get the average power you need to consider the phase difference between them: [itex]P_{ave} = I V \cos \phi[/itex], where [itex]\phi[/itex] is the phase angle by which the voltage leads the current.
I just realized that SGT already said this same thing! D'oh!
Clausius2
P = IV
Maybe did you mean "anything else IS an engineer's confusion"?
If so, read again SGT, mine and Doc Al post. If you keep on thinking I'm wrong, then anything else IS a god knows who the hell's confusion.
Suggested for: Power = current * voltage sometimes?
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
