Can I Safely and Neatly Regulate Power for My Chameleon's Habitat?
In summary: The EcoZone controller is basically what I'm trying to mimic, with the goal being to stay under the $400 price point.
aronweiss19
Greetings all,
This is my first post, and I preface by saying I attempted to search for a solution before posting. Accept my apologies if this topic has been covered in some way; I'll gladly move/repost.
Anyhow, here is the situation: I am a teacher and my students are aged 9 - 12 (Mixed grade level class). We have a class pet, a chameleon. Being that chameleons are relatively exotic they have fairly demanding needs for a stable habitat. They require appropriate lighting for heat regulation and color/wavelength for proper metabolism. This particular species (Chameleo Clyptratus) also requires finite humidity regulation (between 70% and 80%). Consequently the process of plugging in all of the lamps, pumps and humidifiers makes me nervous, both with consideration to load and the presence of water.
Now, I run four lights, an ultrasonic water atomizer (for humidity) and a water pump (to pump water from a larger reservoir to the humidifier.) All of these are plugged into various surge protected power strips with automatic timers to regulate the bunch.
I've calculated the draw and I'm at 6.7 amperes for the circuit, so I feel like the amount of stuff I've got running is relatively safe. I would however, like to have things be both neater and safer.
The problem:
What I would like to do is set up a power regulation/distribution panel the provide as much protection against shorting, fires and shock as possible. I am, however, not exactly sure how to do it. What follows is the general idea I've concocted so far.
I want to run the whole setup from one (or two) grounded plugs into the wall. The plug(s) go through one (or more) AFCIs to a distribution board which then power four GFCI outlets (8 total plugs). After adapting the cord length for each various component, I would then be able to plug in and run all of the components from the GFCI plugs.
The whole setup would be built onto a board that hangs behind the chameleon's enclosure. My goals are to:
1. Keep things as safe as possible
2. Eliminate as much excess wiring as possible
3. Have a single location for power distribution and regulation
4. Keep the set-up such that I can easily disconnect and reconnect components
5. Power the entire habitat from a single cord and outlet
Bonus 6* wire everything up in a way that I can regulate the lamps, pump and humidifier through a program, likely run with my Raspberry Pi.
My Questions:
1. Is this reasonable?
2. Does my design concept reflect what I want?
3. What components would I need to build such a monstrosity? (The GFCIs seem easy enough, but I'm concerned about the 'distribution' point and how to hook up an AFCI to the whole kit.)
4. Tips and tricks on the "how" to go about wiring everything up
All that said, as I'm sure you have gathered, I have an elementary understanding of this stuff at best. I've made simple projects in my time, I can use a multi-meter, I know how to solder, and I can crunch the math for volts, watts and amps.
Thank you kindly for taking the time to read, and I look forward to your responses!
-Aron
p.s. Please feel free to correct my nomenclature and usage.
aronweiss19 said:
...I am a teacher and my students are aged 9 - 12 (Mixed grade level class).
... I have an elementary understanding of this stuff at best
These are two good reasons that you should NOT attempt this build. I would consult a local electrician who knows the "codes" for keeping you and the kids safe.
I appreciate the criticism. You do bring up valid points.
I do wish to continue this discussion, however, being that one of the mission goals of this site is to... "learn and discuss." I see room for improvement in my personal understanding, and the opportunity for a interesting public conversation.
If nothing else, I would appreciate a chances to discuss my ideas with knowledgeable experts. Any input is still greatly appreciated.
meBigGuy said:
Here is the right answer (or better yet, just get a bearded dragon :) )
http://ecozonevivarium.com/products-vivarium-controllers.aspx
Nice find. I've been googling and this is similar to what I envisioned he wanted to do. :tongue:
That is quite similar to what I had in mind. Nice find!
UPDATE: Just read the wikipedia article associated with the picture, took note of the UL and NEC violations. Looks like the EcoZone is the way I go!
1. What is power distribution?
Power distribution refers to the process of delivering electrical energy from a power source to various end users, typically through a network of power lines and transformers. It is an essential part of the electricity supply chain, ensuring that energy is efficiently and safely distributed to homes, businesses, and other facilities.
2. How does power distribution work?
Power distribution works by first generating electricity at a power plant. The electricity then travels through high-voltage transmission lines to substations, where it is stepped down to lower voltages and distributed through distribution lines. These lines are connected to transformers that further reduce the voltage for use by individual customers.
3. What is a power distribution system?
A power distribution system is a network of components, such as power plants, substations, transformers, and power lines, that work together to deliver electricity to end users. It also includes control and protection systems to ensure the safe and reliable operation of the system.
4. What are the different types of power distribution systems?
There are several types of power distribution systems, including radial, loop, and ring systems. Radial systems have a single path for electricity to flow from the source to the end user. Loop systems have multiple paths for electricity to flow, providing a backup in case of a fault. Ring systems have multiple paths that form a continuous loop, allowing for greater flexibility and reliability.
5. Why is power distribution important?
Power distribution is important because it allows for the efficient and reliable delivery of electricity to end users. Without a well-functioning power distribution system, it would be challenging to meet the energy demands of society and provide essential services such as lighting, heating, and transportation. Additionally, proper power distribution can help reduce energy waste and improve overall system efficiency.
  • Electrical Engineering
9K
