Homework Help: Power from Acceleration
  1. Apr 11, 2006 #1
    I am trying to work out power from acceleration and mass alone. But i'm having a mind blank with regard to the actual calculation and it is driving me crazy. :confused:
    Force = Mass x Acceleration
    Work = Mass x Acceleration x Distance
    Power = Work / Time
    Power = Mass x Acceleration x Velocity
    Hence: Power = Mass x Acceleration x Integration of Acceleration
    So from this what should the Power be for the following situation?
    Mass = 5 Kg
    Acceleration at t = 0 sec is 4.2 ms^-2
    Acceleration at t = 0.2 sec is 8.4 ms^-2
    Does a point need to be interpolated on the line to work the acceleration
    and integration of acceleration before it can be placed into the equation?
    Plus as the time between the two values is 0.2 sec does the answer need to be multiplied by 5?
    Thanks
    BH
  3. Apr 12, 2006 #2
    Andrew Mason
    Since power is the time rate of change of energy, find the change in energy of the mass. Assume the KE of the mass at t=0 is 0.
    I think you have to assume that the rate of change of acceleration, a', is constant over the ensuing .2 seconds. So use: a = a't where a' = constant ([itex]a' = \Delta a/\Delta t[/itex]). This makes v a second order term:
    [tex]v = \int_{t=0}^{t=.2} a'tdt = \frac{1}{2}a't^2 [/tex]
    AM
  4. Apr 12, 2006 #3
    Thanks Andrew, I think I have solved it now
