Calculating Power in Circuits
In summary, a person is trying to find the power supplied to different devices in a circuit. They were unable to solve for all of the voltages in the circuit, so they asked for help. They are trying to find the current to each device, but are having trouble with it. They are using the loop rule on the outside loop, but are not sure how to solve for the current to other devices. Finally, they are able to solve for the current to R4 and find that it is 50V. They are also able to solve for the current to R2 and find that it is -50V.
glid02
54
Here's the question:
As seen in the figure below, R1 = 4.00 W, R2 = 8.00 W, R3 = 8.00 W, R4 = 4.00 W, E1 = 50.0 V and E2 = 20.0 V.
(I can't copy image so here it is)
...R1
_____/\/\/\__________________
__.....|...|...._
_..E1.....\.../.R3...__..E2
|...R2./...\.....|
|......|...|...R4...|
|____________|_____|__/\/\___|
(Current from E1 flows to R1 and current from E2 flows to R4.)
I'm supposed to find the power supplied to R1, R2, R3 and R4.
I chose to find the power supplied to R4 first
The 50V charge encounters a resistance of 8 ohm (4+ (64/16)) before reaching R4 and the 20V charge encounters no resistance before reaching R4.
First I tried not including the resistance in R4 which would give
(50/8)^2 * 4 + 20^2 * 4 and that wasn't correct.
Then I tried including the resistance in R4 which would give (50/12)^2 * 4 +
(20/4)^2 * 4 and that wasn't correct either.
I also tried combining the currents before squaring them -
(50/8+20)^2 * 4 and (50/12+20/4)^2 * 4 - and that did not give me the right answer.
I don't know what else to try and the book/internet isn't much help. Any ideas would be appreciated.
Thanks a lot.
I'm fairly certain the direction of the current is as specified. I used the loop rule on the outside loop and it seems to be correct.
You need to solve for the node voltages first, and then use those node voltages to give you the powers.
Call the bottom of E1 ground, then solve for the three unknown voltages by writing their three node equations (the sum of the currents out of a node must equal zero). Please post that work, and then we can check the powers you calculate at the end.
I'm not sure if this is what you mean but I think I forgot the negative charge from both terminals.
So for R1 the currents would be 50/4 from E1+, 20/12 from E2+ and -20/8 from E2-.
For R4 the currents would be 20/4 from E2+, 50/12 from E1+ and -50/8 from E1-.
Now I'm not sure how to find the current to R2 or R3.
For R3: Is it 50/8 from E1+, -50/4 for E1- and 20/6 for E2+ and -20/2 for E2-?
20/6 for E2+ because it runs through R4 and one half of the parallel series and -20/2 for E2- because it runs through only one half of the parallel series.
If this is right then the current to R2 is:
50/6 from E1+, -50/2 from E1-, 20/8 from E2+ and -20/4 for E2-.
Also, should I add up the currents and then square them or square them seperately? Thanks again.
Are you familiar with how to use the KVL and KCL equations to solve for voltages and currents in circuits? Check out the "Analysis of Resistive Circuits" link near the bottom of this wikipedia page:
http://en.wikipedia.org/wiki/KVL
Alright, I'm getting somewhere now but I'm not sure how many loops there are in this circuit. I think it's 5:
Loop 1: E1 to R1 to R2 to E1
Loop 2: E1 to R1 to R3 to E1
Loop 3: E1 to R1 to E2 to E1
Loop 4: E2 to R4 to R3 to E2
Loop 5: E2 to R4 to R2 to E2
Is this right?
I'm partial to the KCL, where you set up one equation per node (excluding ground). Can you set up the 3 equations for the nodes I mentioned in my post #3?
Are the nodes at the resistors or at the intersections of the conducting wire? I checked out the wikipedia site but it's still not making a whole lot of sense to me.
Thanks.
Is it anything like (0-V1)/4 + (V1-V3)/8 + (V2-V4)/8 = 0A and V2 - V4 = 20V ?
with V1, V2, V3, V4 going clockwise from the node between R1 and R2.
After looking again at the circuit, I'd organize it this way:
call the bottom of E1 ground and add a ground symbol to remind you that it is at zero volts (0V). Then call the intersection of R1, R2 and R3 (and the - terminal of E2) a voltage Vx. Then write an equation that shows that the sum of the currents out of the Vx node must equal zero total. The equation looks something like this:
[tex]\frac{V_x - E1}{R1} + \frac{V_x}{R2} + (two other terms) = 0[/tex]
Vx/R3 + (Vx+E2)/R4 ?
I get something different. Summing currents into the node of R1,R2,R3 (and turning E2 voltage around by making it negative... show below):
...R1
__.....|...|....__
_..E1.....\.../.R3..._..(-E2)
|...R2./...\.....|
.....____......
......__...... <-------(I also added a ground)
......_......
[tex]\frac{E_1- (-E_2)}{R_1} + \frac{0-(-E_2)}{R_2} +\frac{0-(-E_2)}{R3}=0[/tex]
Correct. Now set the whole sum equal to zero and solve for Vx. That gives you all the voltages in the circuit, so the resistor powers are just obtained from
[tex]P = \frac{V^2}{R}[/tex]
Sorry, I don't understand Mindscrape's equation, but it may also be valid.
1. How do you calculate power in a circuit?
To calculate power in a circuit, you can use the formula P = VI, where P is power in watts, V is voltage in volts, and I is current in amps.
2. What is the difference between real power and apparent power in a circuit?
Real power is the actual power consumed by the circuit and is measured in watts. Apparent power is the product of voltage and current and is measured in volt-amps.
3. Can power in a circuit be negative?
Yes, power in a circuit can be negative if the direction of current flow is opposite to the direction of voltage. This is known as a reactive power and is commonly found in circuits with inductive or capacitive components.
4. How does the power factor affect power in a circuit?
The power factor is the ratio of real power to apparent power in a circuit. A low power factor means that the circuit is less efficient and more energy is being wasted. It is important to have a high power factor to ensure efficient use of power.
5. What is the relationship between power and resistance in a circuit?
The relationship between power and resistance in a circuit is described by Ohm's Law, which states that power is directly proportional to the square of resistance. This means that as resistance increases, power decreases and vice versa.
