Calculating Power Requirements for Electric Bikes on Inclined Terrain
  • Thread starter stilbiker
  • Tags
    Hill Power
In summary, the power needed to climb a 20° slope with a 100Kg electric bike + 100Kg for the driver depends on the desired speed. However, assuming a constant speed of 80km/h, the additional power needed would be around 14.9 kW or 20 hp. If the speed is reduced to 5km/h, the power needed would be around 1 kW with a 33% margin. It is important to measure the amps drawn by the bike on a level road and to be cautious of sellers' claims for motor ratings, especially if they are from China. The quality of the batteries and controller also plays a role in the bike's performance.
stilbiker
Good Morning to evryboby.
What is the power needed to climb a 20° slope with a 100Kg electric bike + 100Kg for the driver?
Many thanks in advance.
Regards to all. Rudy
Hi stilbiker. :welcome:
The power needed depends on how quickly you'd like the bike to travel up that slope. Do you have a desired speed in mind?
m_total= 100kg + 100kg= 200kg
Assumption: The bike already has a steady speed (say 80km/h) before going up the slope ( before going up hill, the engine has been producing constant power for the bike to go steadily, constant power does not mean the bike will accelerate, as some of the energy produced is lost through vibration, noise etc until the total energy in the system is constant and so it is in steady state and does not accelerate ). The speed of bike is to remain the same during climbing. Assume the ADDITIONAL power needed is constant.
The additional power needed, P_needed is the work needed to be done per unit time to rise the elevation of the bike.
P_needed
= m_total*g*Δz/Δt
sinθ= z/s ,s is the displacement on the slope
z=s*sinθ
Δz= (Δs)(sinθ)
P_needed
= m_total*g*(sinθ)*(Δs)/Δt ,we want it to maintain speed (Δs/Δt) of 80km/h during the climb
= 200kg*9.81(m/s^2)(sin20)(80km/h)*[(1m/s)/(3.6km/h)]*[(1kW)/(1000kgm^2/s^3)] ,since 1kW=1kJ/s=1000kgm^2/s^3
= 14.91207825 kW
which is about 20 hp.
Don't worry about the unit conversion at first. You may "match up" the units to the SI base unit of Watt later.
Hello NascentOxygen. Many thanks for you answer. the speed may be very low, just to access my house, let's say 5 Km/h.
best regards
Hello Curiosity 1.
Many thanks for your answer. Wow 14 KW ! The bike will already have a steady speed (say 20km/h) before going up the slope ( before going up hill, the engine has been producing constant power for the bike to go steadily). The speed of the bike can fall to 5Km/h during climbing, only to reach my house.(about 500 m)
I already bought a 2 KW electric bike who's supposed be able to climb 20 deg. according to the specifications. IT FAIL! I intend to replace the motor with a stronger one.
But 14 KW hub motor is not available.
Best regards.
My figures show that at 5km/hr it will take about an extra 1kw to travel up a 20° slope than for the same speed on the level. (Then I'd throw in a 33% margin on the motor rating.) So do you have a way to measure the amps your bike draws at 5km/hr on a level road?
As far as bike motors go, I'd be a bit chary of the figures sellers may quote, especially if the motors come from China. Also, your batteries & controller may not be as ideal as you'd wish. What are the ratings for the batteries you are using?
1. What is the formula for calculating power needed to climb a hill?
The formula for calculating power needed to climb a hill is P = mgh/t, where P is power in watts, m is mass in kilograms, g is the acceleration due to gravity (9.8 m/s²), h is the height of the hill in meters, and t is the time taken to climb the hill in seconds.
2. How does the slope of the hill affect the power needed to climb?
The steeper the slope of the hill, the more power is needed to climb it. This is because the steeper the slope, the greater the force of gravity pulling the climber down, requiring more work to be done to overcome it.
3. Does the weight of the climber affect the power needed to climb a hill?
Yes, the weight of the climber does affect the power needed to climb a hill. The heavier the climber, the more work and power is needed to overcome the force of gravity and climb the hill.
4. How does the speed at which the hill is climbed affect the power needed?
The faster the hill is climbed, the more power is needed. This is because climbing at a faster speed requires more work to be done in a shorter amount of time, resulting in higher power output.
5. Is there a minimum amount of power needed to climb a hill?
Yes, there is a minimum amount of power needed to climb a hill. This minimum power is equal to the gravitational force pulling the climber down the hill, and any additional power is used to overcome friction and other resistive forces.
  • Electrical Engineering
