What is the Power of a Fluid Pump?
In summary, the question asks for the power delivered to the liquid, which means only the power in the liquid at the point of delivery is important. This results in the answer Av(rho) (1/2 v2 + gh).
symphwar
A pump lifts a liquid of density [itex]\rho[/itex] to a height h and accelerates it from rest to a final velocity v.
What power P does the pump deliver to the liquid, if the liquid is being pumped through
a pipe with a cross sectional area A?
1. Av[itex]\rho[/itex] + [itex]\rho[/itex]gh
2. Not enough information is provided.
3. Av[itex]\rho[/itex](gh + 1/2 v2)
4. 1/2 Av2[itex]\rho[/itex]gh
5. Av[itex]\rho[/itex](1/2 v2) - gh
6. Av[itex]\rho[/itex](gh - 1/2 v2)
7. 1/2 Av3[itex]\rho[/itex]
8. Av[itex]\rho[/itex]
9. Zero, of course; a liquid will naturally flow in that way without any pumping.
10. Av[itex]\rho[/itex]g h
Bernoulli's principle: P1 + 1/2 [itex]\rho[/itex]v12 + [itex]\rho[/itex]gh1 = P2 + 1/2 [itex]\rho[/itex]v22 + [itex]\rho[/itex]gh2
P = W/t = [itex]\Delta[/itex]E/t = F dot v
W = [itex]\int[/itex]F dh
v2 = 2ah
h = 1/2 at2
I'm actually not sure if kinematics can be applied to a fluid. My attempts have so far eliminated answers 1 and 10, though I came up with 10 using the integral of the force F = PA = [itex]\rho[/itex]ghA. Integration gives W = [itex]\rho[/itex]gh2A, and since h/t = v, P = Av[itex]\rho[/itex]gh.
I think what I forgot to take into account was the acceleration-- the pump not only did work to lift the liquid, but also accelerated it. To try to incorporate a change in kinetic energy into the work term, I used
E2 = P2 + 1/2 [itex]\rho[/itex]v2 + [itex]\rho[/itex]gh
E1 = P1
[itex]\Delta[/itex]E = P2 - P1 + 1/2 [itex]\rho[/itex]v2 + [itex]\rho[/itex]gh = [itex]\rho[/itex]gh + 1/2 [itex]\rho[/itex]v2 + [itex]\rho[/itex]gh
Playing around with kinematics I got a = v2/(2h) and t = 2h/v, but all of that together isn't leading me to an answer choice given.
Any advice is much appreciated!
If the question is, "what power is delivered to the liquid", does this mean that only the power in the liquid upon delivery is important? That would imply that any work done to get it to the end point is unimportant -- only the end result matters. What's the power in the liquid at the point of delivery?
If only the end point matters, I guess that would mean the work done is (1/2 [itex]\rho[/itex]v2 + [itex]\rho[/itex]gh), multiplied by the change in volume = Av. That would be Av[itex]\rho[/itex](1/2 v2 + gh). I'm going to feel a little silly if that's the answer-- it is, after all, the one with a form that suggests an increase in both potential and kinetic energy.
Perhaps I'm missing the import of the question, but why would the height lifted matter? If you're holding the hose and measuring the power delivered, you don't care if the water was pumped from the well or from the river or shipped UPS from an Antarctic glacier -- you just care about the water velocity and volume at the nozzle as far as power delivered to the water is concerned.
I think I see what you're saying... are you reading the problem as stating that the acceleration is the result of a power applied after the fluid has been lifted through whatever distance? As though the liquid was lifted, and after that the power in question was applied? I had assumed it was a simultaneous change-- that some power had been applied resulting in both a lift and acceleration. Sorry if I'm misconstruing your meaning!
When I read the phrase, "What power P does the pump deliver to the liquid", I interpret it as asking for the power in the liquid as the "end user" would see it emerging from the pipe. The history of the liquid, how it got to the pipe opening, would be irrelevant.
If the question had said, "What power must the pump consume in order to lift a liquid of density ρ to a height h and accelerate it from rest to a final velocity v through a pipe of cross sectional area A?" then I would agree that the work done lifting the water is to be included in the calculation -- since it applies to the pump power, not the power "delivered to" the liquid.
But as I say, this is just my interpretation of the what the question is saying. Others may not agree with me :smile:
Unfortunately, the answer is indeed Av(rho) (1/2 v2 + gh), but the problems in our database are often worded questionably. Thanks so much for your help!
1. What is the power of a fluid pump?
The power of a fluid pump is the amount of energy required to move a fluid through a system. It is typically measured in units of watts or horsepower.
2. How is the power of a fluid pump calculated?
The power of a fluid pump can be calculated by multiplying the flow rate of the fluid (in liters per second) by the pressure difference across the pump (in pascals).
3. What factors affect the power of a fluid pump?
The power of a fluid pump is affected by several factors including the type and size of the pump, the viscosity of the fluid being pumped, the height and distance the fluid needs to be moved, and the efficiency of the pump.
4. How does the power of a fluid pump impact the overall system?
The power of a fluid pump plays a crucial role in determining the efficiency and performance of a system. A pump with higher power can move fluids more quickly and efficiently, resulting in better overall system performance.
5. Can the power of a fluid pump be increased?
Yes, the power of a fluid pump can be increased by using a larger or more efficient pump, reducing the viscosity of the fluid, or by reducing the distance or height the fluid needs to be moved. However, increasing the power of a pump may also require additional energy and can result in higher operating costs.
