Power of a light source
In summary, the radio station WSFM emits 1.78x10^29 photons per second and has an effective radiated power of 12kW.
googlyeyes
The WSFM radio station (which broadcasts at 101.7MHz) emits 1.78x10^29 photons per second and has an effective radiated power of 12kW.
If the same number of photons were emitted as visible light, what would be the power of the light source?
P=W/t
P = (1.78x10^29)x[(6.626x10^-34)x(3x10^8)/λ]
Strictly speaking, for dimensions the right hand side should be "per second".
Is the problem that you don't know the wavelength?
There are actually multiple parts to this question. Would you like me to type them up with my working for those as well (as that may also be wrong)
Well you can do if you need help with them, however, there is enough information here already for you to answer this question.
I will post it anyway:
QUESTION: Radio station WSFM broadcasts at 101.7MHz with an effective radiated power of 12kW.
(a) What is the value of the momentum of each radiated photon
(b) If an electron had the same momentum, how fast would the electron be travelling?
(c) How many photons does WSFM emit every second?
(d) If the same number of photons were emitted as visible light, what would be the power of this light source?
ANSWERS (so far):
(a) p=2.246x10^-34
(b) p=mv thus v=(2.246x10^-34)/(9.10938x10^-31) thus v=0.000247m/s
(c) 1.78x10^29
(d) P = (1.78x10^29)x[(6.626x10^-34)x(3x10^8)/λ]
Ok, I'm not going to check the numbers but they look in the right ballpark. For (d) you are going to have to pick a suitable wavelength for visible light. This is common in these types of questions. Perhaps that helps?
Ok well I am pretty sure that visible light has a wavelength between around 400-700nm but doesn't that mean there are so many wavelengths that could be chosen and thus many different answers to the question?
Yeah. You could work out the minimum and maximum and give the full range of answers, usually I just pick 500nm and run with that.
Likes 1 person
1. What is the power of a light source?
The power of a light source is a measure of the amount of energy that is emitted by the source per unit time. It is typically measured in watts (W).
2. How is the power of a light source determined?
The power of a light source can be determined by measuring the amount of light that is emitted by the source in a given time period and using the formula P = E/t, where P is power, E is energy, and t is time.
3. What factors affect the power of a light source?
The power of a light source can be affected by several factors, including the type of light source, the intensity or brightness of the light, and the efficiency of the source in converting energy into light.
4. Why is the power of a light source important?
The power of a light source is important because it determines how much light is emitted by the source and how bright or intense the light will be. It is also important in applications where the amount of energy or electricity used by the light source needs to be considered.
5. How does the power of a light source relate to its color?
The power of a light source does not directly relate to its color. The color of a light source is determined by its wavelength or frequency, while the power is a measure of the amount of energy emitted by the source. However, the power of a light source can affect the perceived brightness and intensity of a specific color of light.
