Figuring the Last Digit of x^x^x^x
  • Thread starter bob j
In summary, if you want to find the last digit of an expression like x^x^x^x where x is an integer, you can use Euler's theorem and reduce the base and exponent as much as possible. If x is relatively prime to 10, you can use the fact that x^n mod 10 = x for all even multiples of 5. The key is to reduce as much as possible to make it easier to find the last digit.
bob j
Hi All,
suppose I have something like x^x^x^x where x is an integer. Is there any trick to figure the last digit of the result?
Thank you
You can reduce x modulo 10, the exponent of x by modulo phi(10) = 4, the next exponent by phi(phi(10))=3, and the last by phi(phi(phi(10))=2, can you see why?
not really.. could you possibly give me a simple example?
I was a bit quick, but basically you make repeated use of Eulers theorem that says a^phi(n) = 1 mod n if gcd(a,n) = 1.
What you want is x^x^x^x mod 10. Say, 13^13^13^13. We can by elementary modulo arithmetic reduce the base mod 10, giving 3^13^13^13. By eulers theorem, we can reduce the exponent by phi(10) = 4 (do you understand this?). Thus we need to find 13^13^13 mod 4. Reducing base: 1^13^13=1, hence giving 13^13^13^13=3^1=3 mod 10.
But, if x is not relatively prime to 10, or phi(10), etc.. you must do some other tricks. Say you want to find 5^5^5^5 mod 10. You can however in this case use that 5^n = 5 mod 10 for all n, hence 5^5^5^5 = 5. This works for any multiple of 5. You can do the even numbers for yourself.
Just try to reduce as much as you can. Finding the last digit is almost always very easy.
for your question! Yes, there is a trick to figuring out the last digit of x^x^x^x. It involves using modular arithmetic, which is a mathematical tool for finding the remainder when a number is divided by another number.
To find the last digit of x^x^x^x, we can use the fact that the last digit of a number only depends on the last digit of its powers. So, we can focus on finding the last digit of x^x, which we can then use to find the last digit of x^x^x and so on.
First, we can use modular arithmetic to find the remainder when x is divided by 10. This remainder will be our starting point for finding the last digit of x^x. For example, if x = 7, then the remainder when 7 is divided by 10 is 7.
Next, we can use the fact that the last digit of x^x will be the same as the last digit of x. In our example, 7^7 will have a last digit of 7.
We can then repeat this process for x^x^x and x^x^x^x, always using the last digit of the previous result. In our example, 7^7^7 will have a last digit of 3, and 7^7^7^7 will have a last digit of 7.
In summary, to find the last digit of x^x^x^x, we can use modular arithmetic to find the remainder when x is divided by 10, and then use the last digit of each subsequent power of x to find the final result. I hope this helps!
1. What is the concept behind figuring the last digit of x^x^x^x?
The concept behind this problem is to use modular arithmetic to find the pattern in the last digit of a number raised to a power, and then use that pattern to determine the last digit of the final result of multiple power operations.
2. How do you solve for the last digit of x^x^x^x?
To solve for the last digit of x^x^x^x, you will need to use modular arithmetic and the pattern of the last digit of a number raised to a power. Start by finding the last digit of x^x, then use that last digit to find the last digit of x^x^x, and so on until you reach the final result.
3. Can you explain the pattern of the last digit in this problem?
The pattern of the last digit in this problem is cyclical and depends on the value of the base number. For example, the last digit of 3^3, 3^3^3, 3^3^3^3, and so on, will always be 7. The pattern varies for different base numbers, but it repeats itself after a certain number of power operations.
4. Are there any shortcuts or tricks to solving this problem?
Yes, there are some shortcuts and tricks that can be used to quickly solve for the last digit of x^x^x^x. One strategy is to focus on the last digit of the base number and use it to determine the pattern for the final result. It is also helpful to memorize the patterns for common base numbers.
5. Can figuring the last digit of x^x^x^x be applied to other mathematical problems?
Yes, the concept of figuring the last digit of x^x^x^x can be applied to other mathematical problems that involve power operations. It is a useful tool for quickly finding the last digit of a large number raised to a power, and can be applied in various fields such as cryptography and computer science.
  • Linear and Abstract Algebra
