Power Rule
y=5-1/x
The attempt at a solution
y'=5-1/xln5(-1)(x-2/(x^2)
y'=-5-1/xx-2ln5/x2
But apparently my book says that the x^-2 should be -x^-2
That's what I don't understand. Some help please?
Answers and Replies
6,856
Your thread title, "Power Rule," doesn't apply to the function in this problem, which is in fact an exponential function.
Power rule: ##\frac d {dx}(x^n) = nx^{n - 1}##
Chain rule form of power rule: ##\frac d {dx}(u^n) = nu^{n - 1} \cdot \frac {du}{dx}##
Exponential function rule with chain rule: ##\frac d {dx}(e^u) = e^u \cdot \frac {du}{dx}##
y=5-1/x
You have a mistake above -- that x-2 factor shouldn't be there.
quicksilver123 said:
y'=-5-1/xx-2ln5/x2
You have the minus sign in -1. The book apparently shows it with -x-2. It's like -2 * 5 versus 2 * (-5) -- same result.
No, you misunderstand. I typed what I meant, minus the title error.
The -5 is supposed to be there, but IN ADDITION there is a negative in front of the x in the solution.
Solution from the book:
y'=5-1/x(ln5)[-1*(-x-2)]
Ray Vickson
Dearly Missed
10,706
1,722
The book's solution is correct (although I would have written ##1/x^2## or ##x^{-2}## instead of ##(-1)(-x^{-2})##. Just use the fact that for constants ##c## and ##n## we have
$$\frac{d}{dx} c x^n = c n x^{n-1}.$$
Apply this to ##c=-\ln(5)## and ##n = -1##.
I just don't understand where the second negative comes from. I understand the negative one as that's the sign of the exponent, but what's the negative doing on x^-2? (-x^-2)
Because without the second negative sign to cancel out the first (the first being -1), my final answer is ending up as negative...
6,856
##y = 5^{-1/x} = (e^{\ln(5)})^{-1/x} = e^{-\ln(5)/x}##
##y' = e^{-\ln(5)/x} \cdot \frac d {dx}(-\ln(5)/x) = 5^{-1/x} \cdot \frac d {dx}(-\ln(5)/x)##
What do you get for the part I didn't finish?
Likes quicksilver123
I dunno I haven't got to derivatives of logs in my book yet :(
6,856
-ln(5) is a constant that multiplies 1/x. Surely you've seen a rule on how to differentiate a constant times a function.
Thanks for your reply. Could I please get a step by step method that doesn't use Euler's number
6,856
Post #8 is nearly complete, and goes step by step. All you have to do is differentiate -ln(5)/x. The last part of the equation I showed in post #8 doesn't involve e.
SammyS
Staff Emeritus
1,038
No. We don't give step-by-step.
... but try it this way:
Start with ##\ \displaystyle y=\left(\frac{1}{5} \right)^{1/x} \,.\ ##
I've finished that problem I appreciate it. It seems I've been making dumb mistakes with the signs.
Related Threads on Power Rule
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
