Geometric Series: Summing the Powers of x
In summary: This is maybe the most complicated of the three, practice in rearranging summations never hurt.thanks for all the hints.
kezman
37
Find the sum of the series:
[tex]\sum\limits_{n = 1}^\infty {nx^n } [/tex] if [tex]
\left| x \right| < 1
[/tex]
I thought maybe with the geometric form, but I am not sure.
[tex]
[/tex]
if
[tex]
[/tex]I thought maybe with the geometric form, but I am not sure.
Is it asking for a number, or just if the series converges?
I think for a general solution. It should converge.
Is it asking you to find a power series representation??
It already is a power series... It's asking for an expression for the sum.
You might start by writing out partial sums and see if that gets you anywhere...
[/tex]
How does this differ from your usual geometric series?
[/tex]
Hint : Call the original series S. Write out the first five or so terms in the series. Divide the series by x to get a new series (S/x). Now take the difference between this new series and the original series (S/x - S), term by term and see what you end up with.
The other way to do it is to differentiate a geometric series, but that's more complicated and unnecessary.
Cyclovenom said:
Comparing series like these to derivatives of geometric series is a nice and interesting approach (I used to do this), but in most cases I've found that simply dividing or multiplying by x is an easier approach. :smile:
May as well have a third approach:
[tex]\sum_{n=1}^{\infty}nx^n=\sum_{n=1}^{\infty}\sum_{i=1}^{n}x^n[/tex]
Change the order of summation (absolutely convergent series) then apply geometric series a couple of times. This is maybe the most complicated of the three, practice in rearranging summations never hurt.
The method I had to use is the derivative of the geometric series (similar to the one used for the maclaurin problem) using
[tex]
\left( {\frac{1}{{1 - x}}} \right)^\prime = \sum\limits_{n = 0}^\infty {nx^{n - 1} }
[/tex]
1. What is a geometric series?
A geometric series is a sequence of numbers in which each term is found by multiplying the previous term by a constant value called the common ratio. The general form of a geometric series is: a + ar + ar^2 + ar^3 + ... + ar^n, where a is the first term and r is the common ratio.
2. How do you find the sum of a geometric series?
The sum of a geometric series can be found using the formula: Sn = a(1 - r^n) / (1 - r), where Sn is the sum of the first n terms, a is the first term, and r is the common ratio. If the value of r is less than 1, the series will have a finite sum. If r is equal to or greater than 1, the series will have an infinite sum.
3. What is the common ratio in a geometric series?
The common ratio in a geometric series is the constant value that is multiplied by each term to get the next term. It is denoted by the letter r and is calculated by dividing any term in the series by the previous term.
4. Can a geometric series have a negative common ratio?
Yes, a geometric series can have a negative common ratio. This means that each term in the series will have a different sign (positive or negative). The sum of a geometric series with a negative common ratio can be found using the formula: Sn = a(1 - (-r)^n) / (1 - (-r)).
5. What is the difference between a finite and infinite geometric series?
A finite geometric series has a limited number of terms and therefore, a finite sum. An infinite geometric series has an unlimited number of terms and therefore, an infinite sum. The value of the common ratio determines whether a geometric series is finite or infinite, as a value of r less than 1 will result in a finite sum, while a value of r equal to or greater than 1 will result in an infinite sum.
