Power transfer of a shaft
  • Thread starter rad10k
rad10k
61
Calculate the power that can be safely transferred by a medium carbon steel shaft of 100 mm diameter at 150 rpm ?
Assumed solid circular shaft.
Material : Medium Carbon steel t=580 MPa y= 50 mm k=6 ( table 9 live load varying)
T= Torque
J= polar moment of inertia for a solid circular section = pid^4/32
J=3.14*1 000 000 00 / 32 = 9 812 500 mm^3
tJ/ky = T = 580 * 9 812 500 / 300/1 000 = 18 970.8333 N m
150 rpm / 60 = 2.5 * 6.28 = 15.7 rad/s
18 970.8333 * 15.7 = Power = 298 kW / 745.7 * 1000 = 400 HP
Could someone please look over my answer ?
Answers and Replies
nvn
2,128
32
Excellent work, rad10k. Your answer appears correct. It would be better to leave your answer in standard units (kW), instead of converting to an ambiguous, incoherent imperial unit (hp). There are six ambiguous definitions for the name hp. Just stick with standard units (SI). One minor comment. Your units for J should be mm^4, not mm^3.
rad10k
61
thanks nvn. I will remove the HP from my final answer . :eek:)
rad10k
61
this has come as incorrect ?? any inclination as to why ? thanks
nvn
2,128
32
rad10k: If your tau and k values are correct, then your current answer, 298.1 kW, currently appears correct, and should be rounded to 298 kW. Perhaps post the exact wording of the given question, so we can check it, if you wish.
There is no reason to round pi to less than four significant digits. Please reread the last two paragraphs of post https://www.physicsforums.com/showthread.php?t=463768#post3087641".
Suggested for: Power transfer of a shaft
  • Last Post
  • Last Post
12K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
