Power transmission cable
  1. Feb 24, 2015 #1
    A power station supplies a factory with 1MW of electrical power at a p.d of 10KV. The total resistance of both cables between power station and factory is 0.5 ohm. Find the percentage of the power station output power which is delivered to the output factory.How does this figure change if the supply p.d s only 250V.
    2. Relevant equations
    3. The attempt at a solution
    Well , i tried to find I , which is I = p/v = (106)/(103)=1000A
    Then i use = I2R
    And get 5*105
    But i dont know if am on the right way.
  3. Feb 24, 2015 #2
    Orodruin
    Staff Emeritus
    2017 Award
    So, what do you think the power you now computed represents?
    Also, remember to put units on your numbers.
  4. Feb 24, 2015 #3
    Well to be honest , i don`t have a clue on how to do this question .But am trying to understand and do it.
  5. Feb 24, 2015 #4
    Orodruin
    Staff Emeritus
    2017 Award
    So let us take things one step at a time to figure out what you have computed. In your first step, you say I = P/V. Which values did you put in here and what current does the result represent?
  6. Feb 24, 2015 #5
    Power= 10MW
    P.D =10KV
    Well the answer represents the current at the factory ?
  7. Feb 24, 2015 #6
    Orodruin
    Staff Emeritus
    2017 Award
    Yes, it is the current at the factory. How does this relate to the current through the cables to and from the factory?
  8. Feb 24, 2015 #7
    Well i can calculate the power loss by using p=I2R right or p=V2/R
  9. Feb 24, 2015 #8
    Orodruin
    Staff Emeritus
    2017 Award
    Yes. So the current through the cables must be the same as through the factory.
    You do not have the voltage across the cables, so you must use the first expression. So what you computed is the power loss. How large a portion of the power from the power station does this represent?
Have something to add?
Draft saved Draft deleted
Similar Discussions: Power transmission cable
  1. Power Transmission (Replies: 1)
  2. Power transmission (Replies: 6)
Loading...
