• Support PF! Buy your school textbooks, materials and every day products via PF Here!
Powers of the Matrix M^n
  • Thread starter agary12
1. Homework Statement
I'm in 11th grade and I've been given the following in a series of problems:
(2 0)
(0 2)
Calculate M^N for 1,2,3,4,5,10,20,50. Describe any patterns you observe. Generalize the pattern into an expression for the matrix M^n in terms of n.
2. Homework Equations
3. The Attempt at a Solution
(2 0)
(0 2)^2 =
(4 0)
(0 4)
(2 0)
(0 2)^3 =
(8 0)
(0 8)
(2 0)
(0 2)^4 =
(16 0)
(0 16)
((2 0)
(0 2)^5 =
(32 0)
(0 32)
(2 0)
(0 2)^10 =
(1024 0)
(0 1024)
(2 0)
(0 2)^20 =
(1048576 0)
(0 1048576)
It looks like to me that you can multiply the value in the prior matrix by 2 (for powers 1-5) to get the new value in the next one. For example:
(2 0) (16 0)
(0 2)^4 = (0 16) so multiply 16 by 2 and you have 32. You then know that the matrix to the power of 5 will look like this:
(32 0)
(0 32)
Can someone help me find a rule in terms of n for M^n?
tiny-tim
25,790
246
Welcome to PF!
Hi agary12! Welcome to PF! :smile:
(2 0) (16 0)
(32 0)
(0 32)
Well, you're almost there …
if MN =
(kN 0)
(0 kN)
what is the rule for finding kN? :smile:
I have a question about what you said,
M^N =
(kN 0)
(0 kN)
Is K being multiplied by N or is it just being included to show k is effected by N?
using this particular example:
(2 0)
(0 2)^3 =
(8 0)
(0 8)
What would the K value even be for the above value?
To get 8 from 2 you have to put it to the 3rd power, but that doesn't give me any new information. You could also multiply it by 4, but there is no 4 in the problem.
lanedance
3,304
i think tiny tim is saying try to find;
k(n) = some function n...
can you describe k(n)? (i think you pretty much described it in your last post...)
tiny-tim
25,790
246
It's just an index :wink:
(btw, try using the X2 and X2 tags just above the Reply box)
(2 0)
(0 2)^3 =
(8 0)
(0 8)
ok, that's the N = 3 case …
how about N = 4 … what's the pattern, and the mathematical rule of that pattern? :smile:
rock.freak667
6,230
31
(2 0)
(0 2)
= 2* (1 0)
(0 1)
What does this matrix represent? Now what is any matrix mulitiplied by this matrix?
HallsofIvy
41,681
864
(2 0)
(0 2)^3 =
(8 0)
(0 8)
He is suggesting that you look at the numbers 2, 4, 8, 16, 32, 64, 128, etc., which are what you get with n= 1, 2, 3, 4, 5, 6, 7, etc. What function of n are those?
rock.freak667's suggestion, that you look at powers of [itex]2\begin{bmatrix} 1 & 0 \\ 0 & 1\end{bmatrix}[/itex] is also good.
I'm still confused by what rock freak is trying to say. I understand that this:
(2 0)
(0 2)
is equal to:
2*(1 0)
(0 1)
but why is that even important? Are you suggesting I do something with this matrix?
OH, I just typed it into my calculator and I think I may have found something. Basically this is just a
(1 0)
(0 1) matrix multiplied by 2
The only thing that you are doing when you add an exponent is putting the 2 to a power, at which point it is distributed into the matrix right?
[tex]\left\lfloor[/tex]
K= 2, 4, 8, 16, 32, 64, 128
N= 1, 2, 3, 4, 5, 6, 7
Sorry but I'm not sure what you mena by "what function of n are those," are you saying that I need to find what is done to N to get K? In that case I am not sure. Nothing is being consistently multiplied by the N value to get K (N * X =/= k) since:
2/1 = 2
4/2 = 2
8/3 = 2.66
16/4 = 4
32/5 = 6.4
so there is no relationship found doing what I just did. I'm not sure what else I could do to N to get K.
lanedance
3,304
there's nothing say its a linear relation with n, and in fact its clearly not
you've said it a few times in the post so how about looking again at [tex]2^n [/tex] ?
you've said it a few times in the post so how about looking again at LaTeX Code: 2^n ?
Why do you mean by looking at 2^N?
Basically I've found that the 2 values other than zero in M^n are found by putting 2 to the power you are putting the overall matrix to.
Therefore in this matrix
(2 0) LaTeX Code:^5
(0 2)
I can find the new values by taking 2^5= 32
The new matrix therefore is
(32 0)
(0 32)
Is the rule then just 2^n to find the new values within the matrix? I'm not sure if this is what they are looking for.
In response to tiny tim:
See this is the problem, I understand that you are putting 2^3 to get 8 and that 2^4 is 16, but I'm not sure what the pattern is that they are looking for. They are simply powers of 2, but how can I say this mathematically? And what do you mean by the "mathematical rule of that pattern"?
lanedance
3,304
write down M as a function of n. I think what they want is M(n)
you've pretty much told us in previous posts what this is. M(n) is a multiple of the identity matrix, with scalar multiplier [tex] 2^n [/tex]
this should be enough for what you're trying to do, but for a more general case you could write each specific element of M, to do this think about each element of M
[tex]
m_{ij}(n)
[/tex], where i = row, j = column
note m is diagonal, and multiply of the identity
so what is [tex]
m_{ij}(n)
[/tex]
when [tex]
i = j
[/tex]?
and when [tex]
i \neq j
[/tex]?
in short i think you've got everything you need, just have to pull it together...
tiny-tim
25,790
246
Hi agary12! :smile:
just got up :zzz: …
oh i see!
you've got it, but you think you haven't!
how can you say mathematically "They are simply powers of 2"? …
you say aN = 2N :wink:
ok, so what is MN ? :smile:
M^N equals:
(2^N 0^N)
(0^N 2^N)
Is that it?
Sorry lane dance, I'm not sure what your saying with the i and j subscripts. I haven't ever seen those before.
tiny-tim
25,790
246
M^N equals:
(2^N 0^N)
(0^N 2^N)
Is that it?
Yup! :biggrin:
… except of course please write 0 not 0N
(btw, rock.freak667 :smile: was saying that M = 2I (where I is the unit matrix), so MN = 2NIN = 2NI :wink:)
lanedance
3,304
no worries agary12, look like you've got there, good worki
If you find below confusing, don't worry about it for now, but thought I'll just add a bit for completeness:
the i subscript relates to the row (horizontal line across matrix), so i = 1 is teh first row, i = 2 is the 2nd row & so on. Simialrly the j relates to the column (vertical line down matrix)
So each element of teh matrix is identifed uniquely by a single i,j reference
They don't have to be the letters i & j, its just a reference, could be any letter, but you see i & j quite often in books
in terms of the identity matrix, it is often written
[tex]
\textbf{I}=
[/tex]
[tex]
(1, 0)
[/tex]
[tex]
(0, 1)
[/tex]
[tex]
(\delta_{11}, \delta_{12})
[/tex]
[tex]
(\delta_{21}, \delta_{22})
[/tex]
where [tex]
\delta_{ij} [/tex] is the kronecker delta defined by:
[tex]
\delta_{ij} = 1[/tex], if [tex]
i = j [/tex]
[tex]
\delta_{ij} = 0[/tex], if [tex]
i \neq j [/tex]
in terms of your matrix it would look like
[tex]
\textbf{M}(n) =
[/tex]
[tex]
(m_{11}, m_{12})
[/tex]
[tex]
(m_{21}, m_{22})
[/tex]
[tex]
(2^n,0)
[/tex]
[tex]
(0,2^n)
[/tex]
so you could write your formula for M as
[tex]
m_{ij} = 2^n\delta_{ij} [/tex]
this is equivalent to
M = 2n I
Related Threads for: Powers of the Matrix M^n
  • Posted
  • Posted
  • Posted
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
