Poynting vector in dielectric
  • Thread starter Wminus
29
Hi.
According to classical electromagnetism (and common sense) the intensity of a beam of light entering a dielectric medium should remain constant. Hence the length of the poynting vector must remain constant.
But how do you derive mathematically the last point? Because if you just replace ##c## with ##v=c/n## and ##\epsilon_0## with ##\epsilon = \epsilon_0 n^2## and ##E## with ##E/n^2## you get into trouble when trying to transform the poynting vector.
Let's say you have light entering glass from vacuum with ##n = \sqrt{\epsilon/\epsilon_0}##. => Before: ##<S_{vac}> = \frac{c^2 \epsilon_0}{2} E_{vac} B_{vac}##. After: ##<S_{glass}> = \frac{(c^2/n^2) (\epsilon_0 n^2)}{2} (E/n^2) B = \frac{(c^2) (\epsilon_0}{2} (E_{vac}/n^2) B_{vac} \neq< S_{vac}>##
All thoughts on this are highly appreciated.
EDIT: fixed typo
Answers and Replies
29
Am I being unclear perhaps?
Does the magnetic field not change as well?
29
ahh yes, ##B = B_{vac} /n##? But things still don't work out!
DrDu
775
I can't follow you. S=ExH. In the optical region, ##\mu=\mu0##. The change of E differs for the component parallel and perpendicular to the surface. For parallel E (normal incidence) E doesnt change, so S doesnt either.
In general you have to consider also reflection.
Likes vanhees71 and Wminus
What Dr.Du said (I'll be honest, I didn't follow you at first either). A bound charge on the surface of the dielectric will create a discontinuity on the perpendicular component of the field. The parallel component cannot and does not have a discontinuity, or else you would violate conservation of energy (make a little charged wheel spanning the surface and it will be continually accelerated -- perpetuum mobile). So the "normal intensity" is preserved.
29
But doesn't the E field change by ##E/\epsilon_r= E/n^2## in a dielectric, where ##n## is the refractive index because ##\epsilon_0 \rightarrow \epsilon_0 \epsilon_r##?
In case of no reflection, I thought you could just replace ##\epsilon_0## with ##\epsilon_0\epsilon_r = \epsilon_0 n^2## everywhere in the vacuum poynting vector to get the poynting vector in a material. Was I wrong?
DrDu
775
That's true only for the E field normal to the surface.
29
But you just said in #5 the E field normal to the surface doesn't change?
No, he said for normal incidence of light, the parallel component doesn't change. The normal component changes. If it were not so we would create an opportunity for perpetuum mobile at the surface of the dielectric -- surely you will agree that that is an unphysical result.
Likes Wminus
29
OK I see. Thanks for clearing up the confusion.
No problem, your intuition steered you in the right direction anyway. Oftentimes that is more valuable than having the correct answer from prior study -- for example when you investigate something that hasn't been studied before.
Related Threads on Poynting vector in dielectric
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
