How to Calculate Radioactive Decay with Half-Life Formula
  • Thread starter YTech9
In summary, the first conversation discusses a problem involving a function G(t) and its inverse G^-1(t). The domain, range, intercepts, and asymptotes for both functions are described. The second conversation involves radioactive iodine and its decay model, with questions about finding the formula for f(t), the rate of decrease, and calculating specific quantities. The conversation also addresses finding the inverse of G(t), determining the vertical and horizontal intercepts, and the use of limits in finding horizontal asymptotes.
YTech9
Hey Everyone. I'm at my wits end on these problems, and was hoping for some help. Thanks for any input given.
1)Given G(t)=(1.35)^t+7
A)Describe the domain, range, intercept(s) and asymptotes of G(t).
B)Write a formula for the inverse function.
C)Describe the domain, range, intercept(s) and asymptotes of G^-1(t).
D)Use a table to verify that you computed G^-1(t) correctly.
E) Sketch both functions on the same set of axes.
2)Radioactive iodine is a byproduct of a certain type of nuclear reaction. Its half life is 60days. Suppose that an accident occurs and 45pounds of radioactive iodine is released into the environment. The amount of radioactive iodine decays according to the model: f(t)=ab^t.
A)Write a formula for f(t).
B)By what percent is the amount of radioactive iodine decreasing each day?
C)Calculate and interpret the following quantities. Explain why the values are not equal.
f(4)-f(0)/4
f(7)-f(3)/4
D)How long will it take until 80% of the released amount has decayed?
rather than complete the two four part homework problems for you, think of what you already know about the function. What is the general form for the function. what shifting is ocurring. how does this affect the overall function.
for domain this of what values for t won't yield a result.
For Range consider what values for G(t) cannot come from the equation (hint:can a postive raised to any power be negative?)
Intercepts consider when t is 0 and if/when G(t) is 0.
surely there are examples in the text like this, aren't there?
for c, you can use a general principle that the domain and range of f are the range and domain of f-1.
I'm having trouble figuring out the inverse of G(t)=(1.35)^t+7.
Also having trouble with putting problem 2A) into a formula.
Domain: all, range: all, no vertical asymptote, horizontal ass at y = 7. g^-1(x) = log(t/7)/log(1.35)
if the range is all, then for what input is the output 7?
So for the formula G(t)=(1.35)^t+7
Is the vert. intercept: (0,1.35)
No horizontal intercept?
by the way, especially in light of the fact that at least one person here has given you wrong information, be sure to catch an explanation and/or proof of any claim made before you believe it.
the vertical intercept is (0,y) and the horizontal intercept is (x,0).
if you let t=0, what do you get? ie, what is G(0)? it's not 1.35.
if you let G(t)=0 what do you get for t? ie if =01.35^t+7, what is t? what you get, if anything (hint), is the horizontal intercept.
to find horizontal ass you need to take the lim of the function as x approaches infinity.
or if you're in pre-calc, as the title of the thread implies, and a pre-calc class that doesn't use limits yet, then you could start with the statement given without proof that y=0 is a HA for the graph of G(t)=a^t, 0<a, 1!=a, and argue that your G shifts that HA in a certain way. by the way, this is what i'd do even if i knew about limits.
1. What is precalculus?
Precalculus is a high school level math course that covers topics such as functions, graphs, trigonometry, and algebraic equations. It serves as a preparation for calculus, which is a more advanced math course.
2. Why is precalculus important?
Precalculus is important because it lays the foundation for understanding calculus and other advanced math courses. It also helps develop critical thinking and problem-solving skills that are useful in various fields such as science, engineering, and economics.
3. What are some common topics in precalculus?
Some common topics in precalculus include functions (linear, quadratic, exponential, etc.), trigonometry (trigonometric ratios, identities, etc.), conic sections (circles, ellipses, etc.), and logarithms. Other topics may include sequences, series, and matrices.
4. How can I improve my understanding of precalculus?
Practice is key to improving your understanding of precalculus. Make sure to do all the assigned homework and try to solve additional problems. You can also seek help from a tutor or attend review sessions. Watching online videos and using interactive tools can also be helpful.
5. Is there a specific calculator I should use for precalculus?
It is recommended to use a graphing calculator, such as a TI-84, for precalculus as it can handle complex calculations and graphing functions. However, a scientific calculator can also suffice for most precalculus problems. Make sure to check with your teacher or professor for any specific calculator requirements for your class.
  • High Energy, Nuclear, Particle Physics
  • Calculus
  • Precalculus Mathematics Homework Help
  • Other Physics Topics
