What is the area, in sq. feet, of the debris?
  • Thread starter alyhandra3
  • Tags
    Project
In summary, for question 5, the equation for the parabola formed by the debris field with vertex at (927499.96478, 359333.803) is y=-1.5(x-927499.96478)^2+359333.803. And for question 6, the area of the debris field cannot be determined without knowing the coordinates of the vertex and the height above the ground.
alyhandra3
hello, I need to finish these questions by tomorrow for a project and I have no idea on how to do them due to my absences in the class because of illness. If anybody could provide help, that'd be greatly appreciated.
5. if the rockets collide at F, then the rockets will create a debris field that forms a parabola with vertex at F and scale factor of -1.5. Write the equation for parabola in y=ax^2=bx=c form.
(F as a vertex point is 927499.96478,359333.803
6. The parabola formed by the debris field is actually 3D. When a 3D parabola hits a plane like the land, then the intersection is a circle. What is the area, in sq. feet, of the debris?
Thanks for any and all help
in regards to question 5 i misstyped some of the info..the equation is y=ax^2+bx+c..and the vertex is (27499.96478, 359333.803)
What you apparently missed from class is that the equation of a parabola, with vertical axis and vertex at (x0,y0), can be written y=a(x- x0)2+ y0. a is what you are calling the "scale" factor: -1.5 (negative because the parabola "opens" downward. Just plug the numbers you are given into that.
It's impossible to answer 6 because you haven't told us what the coordinates of the vertex MEAN. If we ASSUME that the y component is the height above the ground, then the debris will hit the ground when y=a(x- x0)2+ y0= 0. You don't really need to solve for x- what you want to know is x- x0- how far away, horizontally, from the vertex the debris hit. That is the radius of the circle.
1. What is the definition of area?
The area is a measurement of the size of a surface or region in square units. It is typically calculated by multiplying the length of one side by the length of another side.
2. How is area different from volume?
Area is a two-dimensional measurement, while volume is a three-dimensional measurement. Area only takes into account the length and width of a surface, while volume also includes the height of a three-dimensional object.
3. How is the area of debris determined?
The area of debris can be determined by measuring the length and width of the debris and multiplying them together. If the debris is irregularly shaped, the area can be approximated by dividing it into smaller, more regular shapes and calculating their individual areas.
4. What is the standard unit of measurement for area?
The standard unit of measurement for area is square feet (sq. ft). However, other commonly used units include square meters (sq. m) and square inches (sq. in).
5. Why is it important to know the area of debris?
Knowing the area of debris is important for several reasons. It can help with cleanup efforts and determining the amount of space needed for storage or disposal. It can also be used to calculate the total volume of debris, which can be useful for estimating costs and planning for removal.
18K
  • Poll
  • Beyond the Standard Models
  • General Engineering
  • STEM Career Guidance
9K
