Precession of a Gyroscope
In summary: I see a mentioned angle to the vertical in the problem statement as 26 degrees from vertical.I think it is important to define the variables before trying to solve a problem.
J-dizzal
394
A top spins at 33 rev/s about an axis that makes an angle of 26° with the vertical. The mass of the top is 0.47 kg, its rotational inertia about its central axis is 5.0 x 10-4 kg·m2, and its center of mass is 3.1 cm from the pivot point. The spin is clockwise from an overhead view. (a) What is the precession rate? (b) What is the direction of the precession as viewed from overhead?
Ω=Mgr/Iω
It looks like most of the variables were given in the problem statement, but I am not sure which I am getting wrong. i tried g=mgcosθ because the angled axis but that didnt work. I am not sure about my r value also.
J-dizzal said:
Ω=Mgr/Iω
A quoted equation doesn't mean much without the accompanying definition of the variables.
You may notice that there's no mention of an angle to the vertical here, so the question is, how is r defined?
The more basic equation is ##\dot L = \tau##, the torque. Certainly ##\tau = mgh \sin(\theta)##, where h is the distance from pivot to mass centre, but what about ##\dot L##? This is not simply ##I \omega \Omega##. That would be the case were it precessing in a horizontal plane, but here it is not. What do you think the equation for ##\dot L## would be?
Ω=Mgr/Iω
where; Ω=precession rate, M=mass, g=9.8m/s/s, r=distance from com to pivot point, I=rotational inertia, ω=spin rate of top.
I see a mentioned angle to the vertical in the problem statement as 26 degrees from vertical. So then r=0.031sin26.
##\dot L## would be the rotational inertia equation for a disk =½MR2 where R is the radius of the disk and M is mass.
##\dot L## should be =Iω, because its a rigid body rotating about a fixed axis.
edit; or would it be equal to the torque because that is the only external force acting on the system?
Haruspex meant that equation did not mention any angle (not the problem statement).
L is Iω, ##\dot L## (with a dot on top) represents the time derivative of it. Yes it would be ##\tau = \dot L## but the question is what is ##\dot L##? (Re-read post#2)Imagine the torque vector in 3D. It is ##\vec R ×\vec {mg}## so it sticks out of your page. It represents the change in the vector L. How does this cause ##\vec L## to change?
Is there any part of the vector L which the torque doesn't change?
J-dizzal said:
Ω=Mgr/Iω
Ok, so why did you interpret it as horizontal distance?
1. What is precession of a gyroscope?
The precession of a gyroscope is the phenomenon in which the axis of rotation of a spinning gyroscope changes direction when a torque is applied to it.
2. How does a gyroscope precess?
A gyroscope precesses due to the conservation of angular momentum. When a torque is applied to the gyroscope, the axis of rotation will shift in a direction perpendicular to the applied torque.
3. What causes precession in a gyroscope?
Precession in a gyroscope is caused by an external torque acting on the spinning gyroscopic rotor. This torque can be applied by a force, gravity, or an external magnetic field.
4. What is the practical application of precession in gyroscopes?
Gyroscopes are used in a wide range of applications, including navigation systems, aircraft and spacecraft stabilization, and even in toys such as tops. The precession of a gyroscope allows for the stability and control of these systems.
5. Can precession be controlled in a gyroscope?
Yes, precession can be controlled by adjusting the magnitude and direction of the external torque applied to the gyroscope. This allows for precise control of the direction and stability of the gyroscope's axis of rotation.
  • Classical Physics
  • Astronomy and Astrophysics
  • Classical Physics
  • Classical Physics
