PRESS Residuals
  1. Sep 6, 2008 #1
    So after studying PRESS residuals I'm curious to know what PRESS stands for, and why it is denoted [tex]e_{i,-i}[/tex]. What is the significance of this particular subscript in the notation. (Not very mathematical questions, I know).
  3. Sep 7, 2008 #2
    statdad
    The results of linear regression - estimates of the coefficients as well as anything else - are easily influenced by outliers Even a single outlier, in either [tex] y [/tex] or [tex] \mathbf{x} [/tex] space, can have a drastic influence on the fit.
    The residuals you are discussing provide one way of providing just how much influence the individual observations have on the overall regression. The idea is to think about removing, one at a time, individual data points from your data set, fitting the model without that data value, then seeing how well this new regression describes the eliminated value.
    I'll concentrate on the data value labeled [tex] (\mathbf{x}_1, y_1) [/tex] - except for notation, the idea is the same for all. The philosophy is
    • Eliminate [tex] (\mathbf{x}_1, y_1) [/tex] from the data
    • Fit the regression using the remaining data
    • Use the new model to estimate [tex] y_1 [/tex]
    The PRESS residual is simply the difference between the estimate of [tex] y_1 [/tex], obtained with the reduced data set, and the actual value of [tex] y_1 [/tex]. Large values of this residual indicate that the pair [tex] (\mathbf{x}_1, y_1) [/tex] have a large contribution to the fitting of the original regression.
    The same idea holds for the other data values.
    It is not necessary to actually refit the regression several times, once for each of the original data values. There are rather simple ways to obtain these values from items calculated during the original fit.
    As you read more on this topic you will also see discussions of internally versus externally standardized residuals. The terminology is extensive, but all of these ideas relate to the same goal: examining a large, complicated, set of data to see which points exert unreasonable influence on a regression. These ideas, and others, fall into the category of regression diagnostics .
    Finally, one short discussion of the ideas in your post can be found here:
    http://www.sph.umich.edu/class/bio650/2001/LN_Nov05.pdf [Broken]
    Good luck.
